(#3951)
Default 03-08-2019, 07:22 PM
Log check please, map 6 at the track. I can feel and tell it's cutting throttle at the top of 1st. I've heard this is common to prevent over rev.
Yes you over-revved first. Lower boost in 1st to improve traction.
Car: q50
Default 03-08-2019, 08:12 PM
You think the timing in high gear isn't too jagged? Ps....12.6 @112. Not bad for a little ol RWD Premium
Default 03-08-2019, 09:10 PM
Seems fine to me, no sharp drops.
Esco Esco is offline
Default 03-09-2019, 07:02 PM
Guess I missed the announcement...
JB4 Methanol Injection Kit for Infiniti Q50 / Q60
Terry,
Any installers you would recommend in the Dallas, TX area?
Car: q50
Default 03-09-2019, 07:16 PM
Terry,
there's a thread specifically for this in this section of the site.
Robyn1114 Robyn1114 is offline
Car: 2017 Q60 Premium AWD
Default 03-11-2019, 12:38 PM
Hello all,
New member here, just ordered my JB4 for my 2017 Q60 premium AWD. I’ve had the car for 7 months now and love it, but it’s time for more power.
I’m from Kansas so I’m limited to 91 octane, will I be able to run map 2 or a tapered map 6 with a max of 5psi on pump gas?
jrobohm's Avatar
jrobohm jrobohm is offline
Default 03-11-2019, 02:08 PM
Originally Posted by Robyn1114
Hello all,
A common question from the non-93 states. Truth is only logging will tell how your Q will handle different maps. Starting with Map2 is a good start - do some runs and post the logs for the forum to review. If all looks good at Map2 - proceed to a slightly higher peak boost map - log the runs - post the logs for review.
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS WMI w/ PM8’s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS LDP
  • AMS CAI
  • Fast Intentions Res. Touring 2.5” CBE
  • Mishimoto Oil Catch Can
Default 03-11-2019, 03:30 PM
Hello all,
Map2 should be fine on 91, we run it all the time on ours.
PRQ50 PRQ50 is offline
Car: Q50
Default 03-11-2019, 03:50 PM
I installed my fuel wires and I’m looking for a way to waterproof the connections, I tried some heat shrink but it didn’t shrink small enough for the wire. I regularly wash my engine bay, and don’t want any issues. Thanks for the help.
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Default 03-11-2019, 03:54 PM
We haven't had any reports of water damage or intrusion on the posi-taps. But the JB4 enclosure itself while water resistant should not be directly soaked.
There are these things called posi-tight but I've never tested them myself: Posi-Tite- Watertite Connector
Car: Q50
Default 03-11-2019, 04:03 PM
I had seen these, but it looks like they are butt connectors, not taps.
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Default 03-11-2019, 04:20 PM
You could also just squirt some dielectric grease on the connection point.
Default 03-11-2019, 05:11 PM
Good to hear, I’ve read elsewhere that even 4psi is problematic on 91 octane. I’ll be sure to log some runs and post them here with every increase of boost.
vietnameeh vietnameeh is offline
Car: Q50
Default 03-11-2019, 05:30 PM
Definitely interested in seeing your results
I have my jb4 just waiting for break in and run 91 octane
Car: q50
Default 03-12-2019, 04:54 AM
That is not a good idea. The engine bay is not meant to be completely sealed and handle direct water intrusion.
Default 03-12-2019, 04:16 PM
We have map1 setup with 4psi in the midrange tapering to 2psi up top, we haven't met a 91 octane fuel yet that can't handle it. And most can handle more. But when in doubt just use the JB4s logging feature to capture the data and find out for sure how the car likes it.
parsonsq50 parsonsq50 is offline
Car: Q50
Default 03-12-2019, 08:31 PM
This is Map7,fuel wires, and E30 mix. How do I read this to know if its safe to turn it up a little more?
Default First log - 03-13-2019, 02:26 PM
Hey Terry
Just finished installing my JB4, here are my first logs, one on map 1 & a short one on map 2
91 octane, completely stock, & 60 degree outside temps
I assume the ecu_psi is what the stock ecu is calling for in boost, if that’s the case then aren’t mine a little high for a non Red Sport, especially with map 2?
Default 03-13-2019, 05:50 PM
I assumed it would ship with the most recent firmware, I guess not. Now that it’s updated I’ll do some more testing tomorrow.
Map 2 definitely leaves a smile on your face, looking forward to trying a torque happy red light to red light map 6 setup
eltiodolfo eltiodolfo is offline
Car: 2019 Q50 Sport
Default 03-13-2019, 07:29 PM
You're on a race gas/E85 mix map. Drop down to map2 and log again.
Here is map 2.
OldLady OldLady is offline
Car: Q50RS
Default 03-14-2019, 01:30 PM
Disconnected my JB4 for an oil change; went to install based on original connection steps and I’m getting a malfunction error when I start up. Can someone point me in right direction? Loose pins or missed connection?
Car: Q50RS
Default 03-14-2019, 02:55 PM
Never mind, back to normal. Something was loose in the control box.
Default 03-14-2019, 04:37 PM
Originally Posted by eltiodolfo
Here is map 2.
Good looking more normal. You could give map3 a whirl.
Default 03-14-2019, 04:38 PM
That's as high as I'd run it, and you may have better results in map5. Evaluate both and see which works best for you.
Default 03-14-2019, 04:39 PM
Some of the earlier harnesses had a tendency to have a pin in the MAP connectors come loose causing a similar thing. If it comes back let our support know and we can swap the harness out for you.
