(#151)
snowmunky's Avatar
snowmunky snowmunky is offline
Car: 2018 Porsche Cayman S
Default 02-12-2020, 05:00 AM
Originally Posted by snowmunky
Annnnddd i just bought another dragy
You know what the best part about this is? I bought the Dragy from Burger Motorsports eBay account that is selling the factory refurbished ones for $99
So, as soon as I get another dragy (hey, I might actually use it this time!), I'll be posting up me times on different maps... As i brought 5 gallons of 110 home with me, sitting in the garage! Also, this unicorn gas station is in BFE Tennessee, seriously, a town with a population of like 2000 people... Takes about 45-50 minutes to drive there, but I'm afraid it's the only gas station I'm ever going to go to again
I was so excited, I took a pic of the damn gas pump (mostly because it's really obscure, and you'd never even know it was there unless they showed you, which thankfully the owner did... And he said that's one of his most popular pumps
onfire onfire is offline
Car: X5 50i F15
Default 02-12-2020, 06:30 AM
Make sure that fuel is unleaded.
snowmunky's Avatar
Default 02-12-2020, 07:00 AM
It absolutely is. THe owner told me exactly what fuel is in the tank that the pump is connected to... it's Gulf Mach 110 ( https://gulfracingfuels.com/wp-conte..._SpecSheet.pdf ) which is a fully unleaded, non-oxygenated fuel.
Same gas station also sells "E10" 87 octane.... and 0% ethanol 87, 91, and 93 octane fuels as well (it's a "Gulf" gas station). It is, literally, the only gas station I have ever seen that sells 93 octane with NO ETHANOL AND carries 110 octane UNLEADED!!! Like I said, only thing that sucks is that it's about ~50 miles away. Well, that and the 110 octane fuel is $9/gallon (which is actually still relatively cheap if you compare that to buying a barrel of Sunoco GT260 or GT260+, both of which are lower octane, and cost $10+/gallon when bought online in 5-gallon drums).
Car: X5 50i F15
Default 02-12-2020, 08:28 AM
Excellent !
Default 02-12-2020, 10:08 AM
Awesome!! Can't wait to see the delta between stock and some map 4 racegas runs!
snowmunky's Avatar
Default 02-12-2020, 02:30 PM
I bought another dragy, so as soon as I get it, I'm going to do some comparison runs...
Most of them will likely be 60-130 (100-200km/h) runs....
I want to do one on map 0 with racegas, one on map 3 with racegas, one on map 4 with racegas.....
And then once the tanks empty, refill it with my normal gas stations 10% ethanol 93 octane with 2.5 gallons E85 (that tested at 73%ethanol with my BMS testing kit)... And the do all of the same runs (map0, 3,and 4) and compare /contrast the differences....
I kind of already know how this is going to turn out because with this 110 in the tank, this car is an absolute BEAST... And I still need to get my exhaust installed and get it on my buddy's dyno! So much to do, so little time.... Why do I have to work? I wish I could just play with my car all day
snowmunky's Avatar
Default 02-13-2020, 04:44 PM
Terry,
I just finished flashing the v5 firmware, should I set options bit 7 back to 0/off?
snowmunky's Avatar
Default 02-13-2020, 05:36 PM
Terry,
Answered my own question.... Car was still "surging" on v5 firmware at part throttle (see logs from timemarker ~315-340ish). Ended up setting bit 7 back on and it went away immediately.
Also, check out these logs on map 4 and map 5 (towards the very end of the logs i switched to map 5 and made one 4th gear pull) !! I think map 5 might be my new favorite! and, I noticed that I'm not maxing out the fuel trims... Even on map 5!!!
File Type: csv JB4 Mobile Logs-v5firmware-racegas-map4-map5.csv (81.9 KB, 2 views)
Default 02-14-2020, 12:59 AM
Definitely looks really good! Glad you're having fun man
