JDARCO JDARCO is offline
Car: 17í BMW M240xi
Default Upgrade Charge Pipe? - 09-24-2018, 01:15 PM
Wondering if anyone here running map 2 or more aggressive has blown a charge pipe. Iíve heard this isnít an issue as on previous motors but want to be sure before I spend the money.
CapitaineBeaver's Avatar
CapitaineBeaver CapitaineBeaver is offline
Car: BMW 230i xDrive
Default 09-25-2018, 04:24 PM
I’ve run quite a long time in map 3 and the rest on map 2 and no issue with the chargepipe. Car has 35000km and JB4 was installed at 5000km.
'18 230i xDrive // Black Met // Coral Red // M-Sport // 719M Black // BMS Billet Intake // BMS JB4 // BMS Pedal Tuner // Dinan Free Flow Exhaust // Roof Rack // 365 days of fun
Bullitt1841's Avatar
Default 09-29-2018, 05:42 PM
Over 30k miles and many 24 PSI runs here. No issues yet!
2018 Audi RS3
2017 F36 440i Gran Coupe | PS2 | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM5) | BMS Intake | BMW 513M Wheels | Dinan Shockware
Default 10-04-2018, 08:19 PM
One of the first things we did was test the chargepipe durability, hoping it would not be up to snuff, so we could make and sell you guys an upgrade. But the stock chargepipe is really good. And to remove it you have to cut off the clamps. Just stay stock it's solid.
jbourne jbourne is offline
Car: F30 320i B48
Default 10-04-2018, 09:15 PM
nice, thank you for the confirmation Terry!
320i B48, been using Jb4 map3 more than 3 months..
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 10-07-2018, 10:33 AM
Looks like it wont be necessary, but i did come across this on eBay and the only one i seen aftermarket until this day. Not sure if that's a bung for meth about 3-4" away from the throttle body: https://www.ebay.com/itm/For-BMW-F20...UAAOSwWxNYwPoy
|2018 BMW 340i|M-sport|Track Pack|
|M-Performance exhaust|CG 5" catted|BMS intake|JB4|BMS Meth kit Dual BM7 nozzles|
RMM RMM is offline
Car: 120i
Default 10-07-2018, 11:34 AM
I got one of the FTP ones for my B48, its similar, actually I needed it for the meth bung, as nobody makes the spacer type for B48, new charge pipe was my only option for meth with B48
FTP charge pipe are well made, they are made in Taiwan with good quality, well machined and nice light weight thin wall aluminum construction
it clips directly on the turbo but with some difficulty as it is hard to reach, probably worse in B58, you need to reuse your original rubber gasket and the C-clip form the stock pipe
