Default JB4 for Acura TLX TypeS Dyno Testing - 01-17-2022, 05:34 PM
Order here: https://burgertuning.com/products/ac...42088091484334
JB4 Map Guide:
Map 0: Disables JB4 all together
Map 1: +3.5 psi, default map. Suggested for 91+ octane.
Map 2: +4.0 psi, Suggested for 91-93 octane
Map 3: +4.5 psi, Suggested for 93+ octane
Map 4: +5.0 psi, Suggested for 30% E85
Map 5: +6.0 psi (30% E85 or race gas)
Map 6: User Adjustable Custom Tuning Map
Map 7: Progressive WMI
Map 8: VALET/Low Boost Map
JB4 Mobile Smart Phone wireless connection directions Click here
BMS data cable hard wired directions&software Click here
JB4 Mobile DEMO:
How to update firmware:
Jonplavist Jonplavist is offline
Car: Civic
Default 01-20-2022, 12:46 PM
Is there an install guide for the Type S?
SerenityNow SerenityNow is offline
Car: 2022 Acura TLX Type S
Default 01-22-2022, 06:39 PM
https://www.n54tech.com/instructions...tall_Guide.pdf
Default 01-22-2022, 06:50 PM
Awesome to see these initial results on the Type S! Hopefully the harnesses are available soon and we can get the full install.
I had the JB4 tune on a Stinger GT1 and it made a world of difference in the power. I feel like the Type S is a similar car in the sense that it’s underpowered in stock, but has tons of potential.
Do you foresee any other mods needed to go along with the tune (like plugs or oil catch can)?
Default 01-25-2022, 10:57 AM
The stock plugs seem fine so far, but we'll continue evaluating as we crank up the power! Nothing else needed that we can tell.
DarkCloudRacing DarkCloudRacing is offline
Car: 2021 Acura TLX Type S
Default 01-25-2022, 11:16 AM
Any ETA update on the new harnesses and tunes for the Type S?
Default 01-25-2022, 02:03 PM
Connectors should be coming this week so we'll keep you all updated soon.
SuperSplash SuperSplash is offline
Default 02-07-2022, 02:19 PM
Just purchased a JB4. Can't wait to install. Any updates on the new harness?
Also, one question I had, what is the benefit of adding the CANbus/OBDII connector?
jinino jinino is offline
Car: MDX Type S
Default 02-07-2022, 03:43 PM
MDX Type S will be out very soon. Since it shares the same engine with TLX Type S, any plan to apply JB4 to MDX?
Default 02-08-2022, 11:16 AM
We expect the same system will be compatible!
Default 02-09-2022, 11:46 PM
Any updates?
Default 02-11-2022, 10:49 AM
We've got the MAF connectors and have a local customer dropping off his car this weekend for us to play with them and confirm fitment.
Default 02-11-2022, 10:57 AM
Sweet, were all eagerly waiting
Default 02-12-2022, 10:43 AM
Looks like connectors fit nicely. Was also able to get a few photos of the "clean" way on the OBDII install which we'll be adding to the guide.
Default 02-12-2022, 03:33 PM
Great news! Just bought mine and can’t wait to install. Just need to find a metal coat hanger for the clean OBDII install :-)
Any more dyno runs or recommended tune settings since the last one?
Also, anyone seen a good CAI for the Type S yet? Terry, you have a nice design for the Stinger that uses the stock airbox. The location in the Type S seems amenable for this same design, right?
Default 02-12-2022, 05:32 PM
We'll do some addl dyno testing next week on the car and see what we can do!
On intakes we're looking at it.
Default 02-14-2022, 08:30 PM
Was able to strap it back down for some additional testing today with our new JB4 integrated MAF control. It certainly made things a lot easier!
Since last time the owner has added high flow *** and an upper chargepipe. We tested on the same ~93 octane fuel (mostly 91 with a couple gallons E85 to simulate 93) to keep it consistent. Surprisingly the mods didn't seem to do much for power. I suspect part of the issue is the factory tuning isn't able to really accomidate them leading to a wonky boost/torque dip in the midrange.
Fortunately the JB4's dynamic MAF control was able compensate on the fly and we quickly got power back on track. I have no way of knowing what the changes really did vs a 100% factory car. But we'll find out sooner or later. I suspect we'd be at around 375whp on a 100% factory car with the current mapping and fuel.
Closing in on 400whp quickly! There is plenty more turbo, the hold up right now is fuel volume. Since the JB4 isn't modifying the factory flash tables we have to work within certain boundaries. Normally to get more fuel trim room we'd hijack the fuel pressure sensor. But on this car it's under the intake manifold so won't be practical. Of course, WMI is a great alternative, so we'll focus some development time on that next.
Car: Civic
Default 02-14-2022, 10:11 PM
What would be a general timeframe for the harness to ship for a current beta user?
Default 02-15-2022, 08:59 AM
I just found out we only have around 5 MAF connectors (a handful were sent early to test fitment), and around 15 BETA customers so far, so a few of you will get them this week and the rest as soon as the bulk of the connector order comes in. Might be a couple weeks after. Not sure yet. They'll be working on getting them out as fast as we can though.
Default 02-15-2022, 09:21 AM
Supplier is shipping to us now so we'll hopefully get it by the end of this week or early next so we can start getting them out to all our customers.
Default 02-15-2022, 06:07 PM
For those wondering how AFR looks during a longer run, here is a 0-100 log. Note AFR remains around stoich until EGT starts to ramp then quickly jumps down to 10.9:1. Also note fuel is cut during shifts momentarily. This is the same logic seen on almost all 2016+ direct injection platforms including those from BMW which we specialize in. So it's no surprise to see it here with Acura.
We may be able to gain some trap speed down the road leaning that out to around 11.8:1 but we'll need a car with a EGT probe mounted preturbo to do that testing safely. For now, we'll leave it as is.
Default 02-20-2022, 09:11 PM
Great development thus far! Cant wait for my new harness to arrive. Glad to see were finally pushing this thing near 20psi.
Default 03-08-2022, 05:52 PM
JB4 installed with MAF connectors (thank you!) along with PRL drop in filter and P2R intake tube. Definitely a noticeable gain especially once the turbo spools up. Still a little lag at the beginning of full throttle - is that tunable? One weird thing on my first WOT on Map2 and in Sport+ mode (logs attached): half way though there was a huge power cut. Very noticeable during the run. How does the log look and any thoughts on why the power cut?
Default 03-08-2022, 06:21 PM
Looks like grazed the rev limiter in 2nd. Is it shifting itself or are you shifting it?
Default 03-08-2022, 06:32 PM
Interesting. It was shifting itself, I was in full auto
