Mazdanation Mazdanation is offline
Car: rx8, mazdaspeed6
Default 01-18-2021, 10:27 PM
registered for updates. Can't wait to see what the 2.5t can do with tuning.
Honeybadger Honeybadger is offline
Car: 2021 Mazda3 Turbo Hatchback
Talking 2021 Turbo 3 - 01-24-2021, 07:16 AM
As an owner of the 2021 Mazda 3 Turbo in a Hatchback, I'm very excited to see it being developed. I've been waiting patiently for parts and tuning solutions, and came across this forum through the Burger site. I had a 2019 I bought in 2019 loaded up with everything from CS, now I have to wait again, haha. Already working on the sound system and matting.
Hope development is going well, I'll be eagerly awaiting updates.
Default 02-09-2021, 10:41 AM
Just as a development update we finally got our car back last week with the new o2 sensor. I was able to get EWG control up and running, but it's looking like we need to take MAF control to do everything we want to do. MAF is running a SENT signal rather than digital or analog so it's a little tricky, but we're making progress.
2018Mazda6 2018Mazda6 is offline
Car: Mazda 6 2.5t
Default 02-09-2021, 10:53 AM
Thanks for the update Terry! Good luck.
Default 02-09-2021, 12:05 PM
That's great news on the catalytic and o2 sensor! Out of curiosity, what is a SENR signal?
Default 02-11-2021, 03:05 PM
It's a newer protocol for handling sensor inputs, one that is a little more complicated for us to process. But we have other SENT based platforms so not a huge deal. Just a little extra time to sort out how to handle it.
legendr34 legendr34 is offline
Car: Cx9
Default 02-13-2021, 01:20 AM
Hello Terry.
Will this eventually be available for the 2017 Mazda CX-9?
Default 02-13-2021, 09:39 AM
Originally Posted by legendr34
Hello Terry.
We plan to cover the entire platform, although technically some of the older models will be a different part number as they appear to use a different TMAP sensor.
Post up photos of your MAP/TMAP sensor and I can verify what you'll need.
335is-dct 335is-dct is offline
Car: 335is
Default 02-15-2021, 02:59 PM
Eagerly awaiting this product because my 2021 Cx-5 turbo needs some help in the power department...
jcrout7992 jcrout7992 is offline
Car: 335xi sedan 6AT
Default 02-17-2021, 05:11 AM
Terry,
The majority of the Mazda CX-5 owners with the 2.5T have experienced a consistent power loss in 1st and 2nd gear when the temperature drops below 20 degrees Fahrenheit. It’s independent of traction, precipitation, engine and transmission temps, you name it. When it drops below 20, there’s no boost until 3rd gear. If you heat soak the engine when it’s less than 20 outside you’ll get normal power for the first pull. After that it drops back down to nothing. Have you seen anything like that so far?
Default 02-18-2021, 03:15 PM
Originally Posted by jcrout7992
Terry,
The majority of the Mazda CX-5 owners with the 2.5T have experienced a consistent power loss in 1st and 2nd gear when the temperature drops below 20 degrees Fahrenheit. Itís independent of traction, precipitation, engine and transmission temps, you name it. When it drops below 20, thereís no boost until 3rd gear. If you heat soak the engine when itís less than 20 outside youíll get normal power for the first pull. After that it drops back down to nothing. Have you seen anything like that so far?
Not something we've experienced but it hasn't been that cold. Photos of your MAP/TMAP connections? We can get a basic system up and running on those now I think to start collecting more tuning data.
On the CX models I think the TMAP is mounted to the top of the intercooler, likely under a plastic cover, as shown in this IC install photo we saw online. I want to confirm it's the same 4 wire sensor on your manifold.
Attachment 100489
Compared to the Mazda3 which has a 3 wire connection for TMAP which is easy to reach from the top, to the left of the airbox.
Attachment 100490
Default Beta Testing - 02-20-2021, 03:16 AM
Any idea when you think there may be some beta products able to be released to us tech and data driven folk? I just got done with a complete overhaul of the audio system from the factory amp out (JL Fix86 and Twk88) and am ready for my next project, lol. There are supposed to be intake and exhaust systems coming along soon too from Corksport. ETA on exhaust is completely unknown atm as it's supposed to be a full ******** and high flow ***/no *** then back. But intake 'should' be this spring. I'm eager to get my hands on the system.
Default 02-20-2021, 10:39 AM
I have a basic system up and running but before we can really release something need to evaluate EWG control, MAF control, and maybe oxygen sensor control. But for those who don't mind helping out with logging, plugging in some addl wires to the PNP connector when we added in additional loops, etc, we could open up some ALPHA testing.
jbradt jbradt is offline
Car: 21 Mazda 3 Hatch Turbo PP
Default 02-21-2021, 10:36 AM
Iíd be interested in the alpha testing.
Default 02-21-2021, 10:37 AM
Preliminary install guide: https://www.n54tech.com/instructions...B4_install.pdf
Default 02-21-2021, 10:38 AM
OK drop me an email we'll set it up. terry@burgertuning.com
Default 02-21-2021, 05:21 PM
I'm happy to alpha test as well. I'll DM you my email and contact number. Best on here or through BMS?
Default 02-22-2021, 02:02 PM
My email is terry@burgertuning.com
Smile 02-26-2021, 09:04 AM
My unit was delivered today after a small delay at the FedEx hub. Solid build quality, I'm impressed!
I'm hoping to install tonight but not sure I can. I will definitely get to it over the weekend though.
Default 02-26-2021, 02:16 PM
josueom josueom is offline
Car: mazda 3 hb turbo 2021
Default 02-26-2021, 06:56 PM
What results have you achieved? greetings from Mexico
AR185163 AR185163 is offline
Car: CX-5
Default 02-26-2021, 08:39 PM
Super excited to see this. I currently have a CX-5 and would love to do ALPHA testing. I would love to support either way, do I need to confirm the TMAP sensor at the intercooler?
Car: CX-5
Default 02-27-2021, 10:29 AM
Attachment 100489
Attachment 100490
Took a look at my CX-5 and removed part of the tray. You are correct, the TMAP is mounted on the passenger side of the intercooler. I couldnít get a good picture of the TMAP but looks to be a 4 wire connection that also has an additional spot where it disconnects on the side of the intercooler. Unfortunately I couldnít get in there any further to read the part number.
Hopefully this helps somehow.
blacksox28 blacksox28 is offline
Car: Mazda CX-5
Default 03-02-2021, 08:58 PM
Made an account just to monitor the status and wanted to state that you'll definitely have another customer if this will work on the 2021 CX-5. Very excited!
TimPro TimPro is offline
Car: 2020 CX-5 2.5T
Default 03-03-2021, 07:56 PM
Should hopefully have a system up and installed by the end of this weekend on my CX-5, will keep you updated.
