jpuehl jpuehl is offline
Car: '12 135i
Default How to identify timing corrections? - 04-30-2019, 07:53 AM
How can I tell I'm getting corrections? Does the value in the "ign_" columns represent corrections? If so, am I looking for columns of all 0's? Also, why is "ign_1" so much different than "ign_2" thru "_6"?
Default 04-30-2019, 11:08 PM
Looks or drops in “ign_1” that’s timing drops
Then if you look at the cylinders in your log- look for delineating values cyl to cyl. Ideally you want all cylinders to “match”
Car: '12 135i
Default 05-01-2019, 06:45 AM
Thanks for the response. I'm trying to use the log to figure out if the gas I'm using is good. For timing corrections, is the lower the number the better? Meaning ideally I'd like to see all zeros? Also if I have a cylinder, or 2 in my case, with numbers really different than the others, should I look at an issue like plugs or maybe injectors?
Default 05-02-2019, 06:03 AM
Zeros are not good = low to no timing
Car: '12 135i
Default 05-02-2019, 07:13 AM
Ugh, that's not good. Looks like I only have 2 cylinders behaving nicely.
Car: '12 135i
Default 05-02-2019, 09:42 AM
Is there a way to find out the target timing? I have the BMS BEF to go along with the JB4. Also, are the numbers displayed in the log the actual timing? I can assume that 0 is that what was targeted but without knowing what the target is I don't know how far off the actual timing is. To help with the timing I should probably lower my boost safety to limit boost.
Car: '12 135i
Default 05-02-2019, 01:57 PM
I was just looking at some logs from almost 2 years ago, before I changed my coils and plugs, and timing looked a lot better and more consistent across the cylinders.I think I'm going to do a back-to-back test with my current replacement coils/plugs when reinstall the OEM parts and test the swap just coils (so new coils old plugs) and see how the logs compare. The new coils/plugs may have been a waste of money.
They're Delphi coils and I did have one fail in < 10k miles. It was replaced no charge.
Actually I should test:
new plugs/new coils
new plugs/OEM coils
OEM plugs/OEM coils
OEM plugs/new coils
Default 05-02-2019, 11:49 PM
Look at “ign_1” for that / “target timing”
maxihari maxihari is offline
Car: 2011 335i
Default 05-07-2019, 07:35 AM
Ideally, it would be best to have "field - cell definition document" or mapping...
What is it, what is it used for, nominal values.. things like that.
i.e. AVG IGN - Mean value of Ign 1-6? Target?
Load?
FF?
etc..
2011 N55 MSport 6spd
DP, PPK, JB4 w FF, FMIC
Car: '12 135i
Default 05-07-2019, 08:52 AM
Thanks Dave. If "ign_1" is target, how can I tell what the timing actually is for #1? I'm asking because I'm trying to get my timing consistent across the cylinders and I have no idea how #1 looks.
Also, how does "the computer" know how to adjust/correct each cylinder?
Car: '12 135i
Default 05-10-2019, 08:29 AM
I'm noticing that I'm having timing inconsistencies between cylinders on different maps. On map 1, cylinders 4 and 6 seem having a hard time reaching target. After a pull on map 1 I switched to map 5 and gave it a few days to "learn" and did a pull and without making any changes to the ignition and cylinder 4 looks great and now cylinder 2 is lagging.
I look at other logs people have posted and notice their timing is consistent between cylinders. I've changed coils and plugs, swapped back to old coils on cylinders lagging in timing. What could the problem actually be? I just bought a JB4 for my wife's car, I could probably swap it with mine and see if I still have the same issues. It's getting frustrating because I think the car has more in it if I could get the "tune" straightened out.
KhrizJ KhrizJ is offline
Car: Veloster n
Default Ign timing - 01-28-2022, 04:45 PM
My average ignition is 1.5 to 2.1 full throtle on 93 pump gas is that good or should be higher??
Default 01-31-2022, 06:14 PM
Best to start your own support thread and upload a log for input.
