jtrejo jtrejo is offline
Car: 535 2008
Default Log review map6 22psi - 01-21-2022, 07:06 PM
thanks
Pure stage 2 turbo
Dorch stage 2 HPFP
Fuel it stage 2 LPFP
VRSF intercooler
VRSF down pipe
Burger filter
FTP piping inlet boost pipe etc
Burger charge pipe
E85 fuel
2015 535 - JB4 - Pure Turbos Stage 2 - VRSF DPipe- Burger Intake - Straight piped - MHD Backend Flash - BMS Meth - VRSF Intercooler - VRSF Charge Pipe - Dorch Stage 2 HPFP - Fuel it stage 2 LPFP
Car: Evo VIII
Default 01-24-2022, 12:39 PM
You are maxing trims for most of all the pull. Timing starts to get pretty sporadic in 4th gear as well. Are you on straight E85?
Car: 535 2008
Default 01-25-2022, 12:12 PM
yes straight E85. we adjusted some things to correct. here is one map
Car: Evo VIII
Default 01-25-2022, 01:27 PM
DME dropped with the log, and would be more flash related. What flash is your car currently running? Please provide some additional logs to see if it's a trend or if it was just a hiccup.
Car: 535 2008
Default 01-25-2022, 04:21 PM
running ps2 e85 map. heres a couple logs from my dyno session today
Car: 535 2008
Default heres todays dyno - 01-25-2022, 04:23 PM
503HP and 560Tq
Default 01-25-2022, 04:46 PM
Map 6 looks pretty normal. A little left in the turbo but there a couple timing corrections...not bad though.
Car: 535 2008
Default 01-25-2022, 05:29 PM
new plugs gapped to .20 and new coil packs. what do you think the timing issue might be?
Car: Evo VIII
Default 01-26-2022, 11:43 AM
Pretty normal. Have you checked your local suppliers ethanol content recently?
Car: 535 2008
Default 02-01-2022, 10:07 AM
no, or should i get a analyzer from fuel it?
Default 02-01-2022, 12:07 PM
Its always best to know and monitor your ethanol content as it can vary greatly.
Car: 535 2008
Default 02-01-2022, 12:42 PM
how does it connect to the JB4? can you send me link
Default 02-02-2022, 12:37 PM
You'll need to purchase the flex fuel kit and then you'll connect the white signal wire to pin location 16 on the JB4's DB25 connector and enable bit 1 under the WMI/E85 options.
https://rz2n4uvipxrtakmu-54960062603...hassis-n55-bmw
Car: 535 2008
Default 02-04-2022, 12:18 PM
but i have a blue wire connected there for the EWG kit in that pin
Default 02-07-2022, 12:13 PM
Then you can connect it to pin location 3 and enable bit 0.
