GokhanO GokhanO is online now
Car: bmw 125i
Default b48 125i jb4 issues - 01-19-2022, 08:59 AM
Hello guys
I have a f20 125i with b48b20b engine. I installed jb4 and i have some problems;
I used to own turbocharged hondas and we used to kept our afr under boost like 11.5 12. But in this car in the wot runs i always see values close to 14.7 till redline. I know this engine is a direct injected engine and designed to run a little lean but i am not feeling comfortable what do you think ?
My second problem, in the map2 when making wot runs, when i pushed the accelerator, it feels like there is a bump in the acceleration, it is not smooth.
I took some datalogs ( map 0 map1 and map2 ), would you please have a look to them ?
Default 01-19-2022, 12:51 PM
Put all your user adjustment settings back to the default values and do another set of logs. Those settings are incorrect...here's the link for the default settings.
JB4 B48/B58 Firmware, Settings, and Notes - N54Tech.com - International Turbo Racing Discussion
Car: bmw 125i
Thumbs up 01-19-2022, 01:23 PM
Thank you very much, i will correct them and do another set of logs
Car: bmw 125i
Default 01-20-2022, 09:03 AM
Today i changed the settings and made couple of logs in map1. But it seems afr values are again locked at 14.6 14.7 and also when i first press the accelerator i am feeling a sudden bump for a short while.
Please have a look at my logs, thanks.
Car: Evo VIII
Default 01-20-2022, 11:43 AM
Is your traction control all the way off? I'm not seeing any real issues here.
Car: bmw 125i
Default 01-20-2022, 11:46 AM
Yes it is completely off, so you are saying those afr values are not on the lean side ?
Default 01-20-2022, 11:50 AM
The DME determines the AFR's and yes, they do run lean from the factory. But you're not running very much boost and you don't have any timing corrections....looks normal.
Car: bmw 125i
Default 01-20-2022, 11:55 AM
Ok I understand so I think I can try map2 and map3, I am using 98 octane(ron) here.
Default 01-20-2022, 12:11 PM
Upload a log on map 2 and then we'll go from there.
Car: bmw 125i
Default 01-20-2022, 12:21 PM
Ok I will
Car: bmw 125i
Default 01-29-2022, 02:01 PM
here are some logs for map2 and map3
Default 01-31-2022, 06:21 PM
Map 3 looks pretty good. Trims are pretty high so don't add any ethanol.
