TonyGotSkilz's Avatar
TonyGotSkilz TonyGotSkilz is offline
Car: 07 335i Black on Black
Default Log Review - New Pure600 turbos - 09-26-2021, 04:50 PM
Hi, I've attached a log for review. I'm trying to get the most out of my new pure600 turbos on my 2013 335is. I'm FBO, stage 2 LPFP, 3.5bar tmap, pure600's with 2 inch inlets / outlets, forged diverters and the latest hybrid BEF on e85 (running e50-e60) . Ran map 2 for awhile but wanted more so running map 7 now (I have logs on map 2 also if that helps).
I'm going to get a custom tune soon but wanted to see how far i can take the JB4 BEF combo first. I feel like the turbos are spooling a bit slower now then they were before I did the BEF. I'm shooting for a consistent and reliable 550WHP which seems doable with my setup (I hope).
This is my second 335i and both have been tuned but this if my first time going with larger turbos. So far so good. The Pure's have been in 3 weeks now with no issues so far.
Thanks in advance for checking out my logs.
https://docs.google.com/spreadsheets...it?usp=sharing
ruskiracer ruskiracer is offline
Car: e93 335i
Default 09-26-2021, 09:55 PM
Log looks pretty solid and clean
Manual swapped e93, single turbo precision 6875
Default 09-27-2021, 11:26 AM
Please upload the CSV files to this post for us to review them. Thank you
Default 09-27-2021, 01:46 PM
Here you go
P32_M2_R7_210926_1124 - P32_M2_R7_210926_1124.csv
2013 335is N54 DCT
Pure600 Turbos, 2 inch outlets and inlets, VFRS - DP's, VFRS - 7inch intercooler, JB4, BMS Anti-lag, Stage 2 LPFP, Oil catch can, Forged diverter valves, 3.5 bar map sensor
Default 09-28-2021, 12:05 PM
For proper review and the JB4 to adapt, please do logs in 3rd or 4th gear from 2K rpms to redline at wide open throttle.
I'd also keep an eye on cylinder 4 as it's getting a lot of timing corrections. You may want to run a little less boost until you have it dialed in and then slowly work the boost up.
Default 09-29-2021, 03:50 PM
Here is the latest run 3rd gear pull from 1900 on Map 7 along with my app setting.
File Type: csv P32_M7_R2_210929_1323 - P32_M7_R2_210929_1323.csv (26.1 KB, 85 views)
2013 335is N54 DCT
Default 09-29-2021, 06:28 PM
No need for huge images...I can see all of that in the log.
I'd stick with that map and wouldn't add any more ethanol as your HPFP is struggling a bit.
Default 09-30-2021, 08:31 PM
Thanks, I'm at around E60 right now i'll lower to E40-E50 and keep an eye on it. HPFP is only 6 months old but thats a lot of corn juice. I've heard that more Ethanol doesn't mean more power always for the N54 is that true? Any advice on optimal Ethanol amount or is it just whatever your HPFP can handle? Going for a custom tune soon and want to target a reliable amount of Ethanol with that tune.
2013 335is N54 DCT
Default 10-01-2021, 08:49 AM
Ethanol=octane=more aggressive tuning. The age of the HPFP doesn't matter, it can only push so much volume. Ethanol requires more volume so the overall power limitation is reduced the more ethanol you add and it becomes a balancing act until you upgrade to port injection etc.
