Car: M550i
07-02-2021, 02:52 AM
You will need to go full throttle up to redline for a proper log. I have no doubt it will hit all the boost targets without fuel and timing trims in map1 and the conservative map6. Map 2 is the question...
Car: 2007 335i Sport
07-06-2021, 06:50 PM
https://burgertuning.com/collections...=3016859222040
Is the N63 550i Replacement Control Board in the drop down menu for the G chassis or the F? JB4 not powering on, already replaced "N63 Masterchip" thx
Car: 2006 BMW 330i
07-08-2021, 09:11 AM
I'm new to this JB4 application and want to play around with MAP 6. I like Map 2 in my X5 M50i but I feel its a big hit midrange than it falls off on the top end making the X5 feel like it ran out of juicy. How would I setup MAP 6 to give me a solid pull all the way through vs a big punch than nothing?
07-08-2021, 09:26 AM
Originally Posted by dlnkwnt
NO, not the same board. Ando at Support@jb4connectkit.com helped me out... informative and efficient. The correct board is on its way. Thank u
Car: M5501
07-19-2021, 01:10 AM
BMW finally got around to upgrading my software to 07/2021.20 from 03/2021.40. I noticed immediately how firm the car's stance feels while driving and how smooth the car drove and shifted gears. Testing is with no JB4 as I had to take that off for a visit. But the car feels so much easier to control, and the power on stock felt beefy compared to the previous software. Dare I say it felt like a different car??? Anyhow, this is just my first impression after driving it a few hundred miles on no tune and just a software upgrade.
Fast forward to today, 19 Jul 21. I drove the car a good bit before work on the way to grab some coffee as I wanted to test the car's balance with a new rear sway bar. I want to say this investment is well worth it. It took 1 hour to install, using a lift and making sure my 4-year-old didn't run into the street.
Altogether, it was four bolts and two nuts. The bar itself was tricky to remove once unbolted. The driver-side control arm needed raised an inch to slide the bar out.
I hope this is informative.
Zach
2021 M550i
Bernina Grey Amber Effect
GPower High Flow Air Filters / Charcoal removed
GPower Axel Back High Flow Sport Silencer
Active Autowerke High Flow DwnPips
HardRace rear sway bar and Dinan lowering springs
Barracuda Racing Wheels (Inferno)
JB4 Map 2
Retired:
2009 335xi
Completely Moded out
Beat corvettes - they were pissed
Car: M550i
08-07-2021, 12:24 PM
Couple of us 523hp m550i jb4 users are noticing that with launch control, 4th gear short shifts when you are running a quarter mile sprint. Problem doesn't occur in map 0. It loses quite a lot of time from the run and it pretty annoying! Is anyone else here aware of this as well?
Anti-Social
Car: 2021 M550i xDrive
08-07-2021, 12:50 PM
I'd guess its shifting at a particular speed. And since Map 0 has less power, it needs more rpm to hit that speed.
Mike Levy
Car: M550i
10-21-2021, 03:16 PM
I did a LC tonight, cool and a little bit damp. The car did it from middle of 3rd this time, chucked me straight into 4th. Got me thinking it might be due to the fact LC operates with traction semi on, if the car detects too much wheel spin in knocks you up a gear.
Car: M5501
10-21-2021, 09:53 PM
I have not talked to you guys in awhile. I have not used LC yet but I am interested in your feedback.
Also, on another note please remove the charcoal filters in your intake track. If you have them and I did but now after removal the cars throttle seems much more responsive. It's a 15 - 20 min job and so worth it.
2021 M550i
JB4 Map 2
Retired:
2009 335xi
Anti-Social
10-30-2021, 05:55 PM
Does anybody have the CAN-Flap working on the G-series? Its not working on my car, with the BC button or the JB4Connect app.
Mike Levy
Car: 2018 bmw m550i
11-17-2021, 01:41 PM
How do I contact Terry or where do I send logs to? I think I am getting some boost creep after installing 🐈 less dp.
11-18-2021, 01:48 PM
Start your own support thread and post up.
Car: 2014 335i M-Sport
11-25-2021, 10:26 AM
Originally Posted by zse8h
So, the 2021 M550i was picked up late last week in Wurzburg Germany - What a beautiful city I might add. I am babysitting it until 1000 miles, as the dealership told me to do than at that point I can take it over 4k rpms.
I did install the BMS wheel spacers 13m on the back and 10m on the front and boy what a difference in the stance. I sprayed them with high-heat rust-oleum in attempt to prevent rusting. It's like my 335i when I added 9.5s to the rear.
I started poking around in the engine bay and the TMAPs are very easy to get to and have 3.5 sensors.
The jb4 should be here Monday so il install it and do my best to stay under 4k rpms. Easy to do on the small german roads but the autobahn is a different story.
Zach
Hi Zack,
Please post a pic of your car with the BMS 10mm spacers front and 13mm rear. I want to get spacers but I don't know which sizes to get for a semi-flush look. I also ordered the MSS springs. Hoping to get the car in a nice stance.
2003 E39 M5 - Sold
2013 335i MSport - Sold
2018 C63s AMG - Sold
2021 M550i
Car: 2022 X5 m50i
12-15-2021, 06:42 AM
Any newer maps or updates for this platform? Pretty popular and the most recent tech BMW has…
12-22-2021, 09:54 AM
For the N63R? We tune around 20 of them per month, have been since they came out. Map1 and map2 are solid and for customers who want to push more map6 is in there for custom settings.
Anti-Social
12-22-2021, 10:48 AM
He’s looking for the N63B. Map 1 is fine. Map 2 isn’t happy.
Mike Levy
Car: M5501
F90 M5 BMS intakes -
12-30-2021, 06:44 AM
Please tell me these will fit a M550i? If I take 2 pictures, 1 of a M550i and 1 of a M5 (engine bay) it looks like the turbo inlets sit in the exact same arrangement. If so, the BMS intakes will fit the M550i as well?
Has anyone tried?
@Terry can you send me some to try? You will sell more product if the indeed fit!! If they don't ill send them back.
2021 M550i
JB4 Map 2
Retired:
2009 335xi
12-30-2021, 08:01 PM
Has anyone tried?
I think we tried and they were different. Can't send a new set but if we ever have a used set around wouldn't mind. Or get an M550 to swing by our office in Simi Valley for a test fit. We'll throw in a free dyno.
Anti-Social
12-30-2021, 08:24 PM
You wouldn’t let me buy the used set last time you had one! That’s when you said you were working on an M550 set. How about you just sell me the pipes at cost and I'll screw with it? I have filters, and I can get silicone reducers. Or at least share the bend angle so I can pick up a set of bends from China. :p
The inlet size is definitely different, so reducers will be needed to attach them to the piping. Otherwise everything looks pretty much the same…… except the ducting behind the grills. The F90 has larger caged inlets back there and the M550 just flat louvered panels. I’ve wanted to retrofit the M5 parts since I got the car, but I don’t think there’s enough clearance to allow the grill shutters to open and close.
EDIT: Also the M550 airbox bottoms need to be gutted. I was messing with my custom setup today and tried keeping the bottoms in place like the BMS one does. The vertical bars and press fastener stations (that hold the foam) are in the way. Thats all gotta be cut out. Not a big deal, its pretty thin plastic. The bars could probably be scored with a blade and snapped off if theres no cutoff tool available, and the stations can be cut off with wire cutters and filed smooth. There are small areas by the back of the box with spring loaded doors that are kinda in the way, but you could probably work around them with the pipe bends.
EDIT 2: My version 1 should be done in the next day or 2. V1 uses 3" pipe. Theres also going to be a V2 with 3.5" pipe at some point. I don't think 3.5" is necessary, or really a good idea, which is why I did the smaller version first. I'm not thrilled with the idea of reducing pipe diameter and increasing velocity twice. I feel like the high velocity air slamming into the turbo impellers could cause excess wear or possibly damage.
Mike Levy
Car: 2022 BMW X7 M50i
03-11-2022, 07:20 AM
Looking for recommendations of Chicagoland based shops that can install & fine-tune JB4 on a 2022 M50i engine...
Anti-Social
03-11-2022, 03:20 PM
Theres not really a lot of fine tuning we can do. Best to just install it yourself and run Map 1
Mike Levy
03-11-2022, 04:27 PM
Sure we can discount a set for you to check out. Drop me an email to sort out the details. Terry@burgertuning.com
Anti-Social
03-11-2022, 07:04 PM
I'll mail you tomorrow. I got another month before my X3 build date, so I can screw around with some stuff while I'm waiting.
Mike Levy
Car: M550i
03-13-2022, 12:16 PM
Originally Posted by BimmerFan
Hi Zack,
These are BMS spacers 13 & 10mm. Interested in how you find the MSS springs on a m550i.
03-24-2022, 04:17 PM
I have fitted the MSS springs for about a month now and all I can say is if I had to do only one mod on this car, the MSS springs would be it. oh my lord! I think the MSS springs are worth a whole lot more than they retail. It lowered the car 19 mm all around and I installed a set of Rohanna rfx 11 wheels in bronze. Stance is sick. The ride quality is actually better and more comfortable than stock and I need no spacers. The wheel offset is perfect and I went one tire size wider front and rear. I am over the moon. Now all I need is for Terry to unleash the full potential of this car and I'll be good for a few more years.
2003 E39 M5 - Sold
2021 M550i
