TTM5 TTM5 is offline
Car: M5
Default 2021 Q5 - 04-06-2021, 12:46 PM
Hello Terry, how much extra power you looking to make with JB on a 2021 Q5 2.0T w/12v electrical system and when is the ETA?
Default 04-06-2021, 06:55 PM
We need to make a modification to the harness. Car should be good for around 315hp on 93. The 12V motor only works when cruising and on initial spool up.
Haven't looked and one of the PHEV yet.
2021 VW Golf 8 R
Car: M5
Default 04-06-2021, 07:38 PM
Tkx George.
Ok whats the eta on the harness?
Default 04-13-2021, 06:54 AM
Tkx George.
I am having difficulty sourcing the one sensor so we can bench test it as its in back order so once that is done will be able to have a ETA. The current harnesses will work so most likely we will only need to swap a plug which we have stock of in house and not at the harness manufacturer. We make these in the US so there isn't major lead time regardless.
2021 VW Golf 8 R
Car: M5
Default 04-14-2021, 02:19 PM
Ok waiting, what will be the price?
Default 04-14-2021, 02:52 PM
$429, the same as the rest of the Group 6 units.
2021 VW Golf 8 R
Car: M5
Default 04-23-2021, 01:01 PM
Let me know when u have em’ ready tkx
Car: M5
Default 06-07-2021, 07:49 PM
Hey man, is this ready?
Default 06-08-2021, 04:41 PM
We still working on it. It turns out two of the sensors are SENT technology so a new board needs to be used.
We working simultaneously on the MK8 R that I have with me and it has the same layout in terms of sensors so it will be a direct carry over of the R but with tuning suited to your engine.
Edited to add that only a Jb4 will be available.
2021 VW Golf 8 R
Car: M5
Default 06-09-2021, 07:26 AM
You said above it was 1 sensor. When will this be finished and thoroughly tested on a 2021 q5 not R?
Default 06-09-2021, 07:48 AM
I would say in a months time at most.
2021 VW Golf 8 R
Car: M5
Default 06-17-2021, 11:20 AM
Does the MK8 R use the same turbo as the 2021 q5 2.0? Will u be able to make the same power as the R or 330+hp?
Default 06-17-2021, 12:33 PM
330hp or so. Looking more into things it looks like the 262hp motor is closer to a Gen4 motor than a Gen3.
2021 VW Golf 8 R
Car: M5
Default 06-18-2021, 07:51 AM
Do u have a 2021 q5 to test with?
Default 06-18-2021, 08:41 AM
We have managed to source a 2021 A6.
Are you local to us?
2021 VW Golf 8 R
Car: M5
Default 06-18-2021, 08:44 AM
No, I am not....
Car: M5
Default 07-04-2021, 10:24 PM
George, its been almost a month now. Do you have the q5 jb4 ready and how much power?
Default 07-05-2021, 06:05 AM
We should have news and dynos this week.
2021 VW Golf 8 R
Car: M5
Default 07-07-2021, 06:12 AM
Where do i see this?
Default 07-07-2021, 06:19 AM
Will post here but if all goes well the unit will be also listed in Group 6 in the drop down menu with information on the sales page: https://burgertuning.com/collections...l-audi-porsche
2021 VW Golf 8 R
Car: M5
Default 07-07-2021, 06:33 AM
Ok, will you post the information on 2021 q5 here this week? How much power on 93-94?
Car: M5
Default 07-13-2021, 07:15 AM
Any dyno sheet yet? Logs?
Default 07-13-2021, 07:17 AM
AFter or on this weekend.
2021 VW Golf 8 R
Car: M5
Default 07-13-2021, 01:23 PM
Does the 2021 q5 use the same motor/turbo combo as the gti or R? How much power more or less?
Default 07-13-2021, 02:30 PM
Engine is like new GTI and turbo remained the same as 248/252hp version. On 91 around 310hp and on 93 around 315hp or so on the 252hp version so the ouput should be more on yours.
2021 VW Golf 8 R
