Car: BMW M235i
04-28-2018, 08:17 PM
If your question is why do we run the N55 motors so lean it's because the fuel pump is weak and can't maintain pressure well at richer targets, and due to DI the motor tends to run better leaner, in our years of experience tuning it.
Hi Terry. Will the AFR be different (more rich?) from JB4 only vs JB4 + BEF? I'm FBO and JB4 Map 5 log AFR is about 14.8-15 at around 4000rpm and about 11.7-12 at about 6000 rpm. Will my AFR be a tad richer with the BEF? I am a newbie in tuning, and from what I have read is turbo engines should run richer to lower temps and decrease knocks.
Thanks.
2014 BMW M235i auto. JB4 & EWG connector + BEF (BMS EWG Race 10 map), 98 RON pump fuel (93 oct), BMS WMI kit (dual BM5 nozzles, 80% meth mix, boost additive 50, Scaling 60, min flow boost 6.5), GruppeM intake, ER CP, Forge BOV, Wagner Evo II competition intercooler, ER ******* **, eisenmann exhaust, quaife LSD.
Car: BMW M135I
04-28-2018, 10:39 PM
Sounds like you're just confused. Obviously with the BEF we adjust the fuel trims and AFR targets. Logs in the link look as mapped.
If your trims are sticking at 50 or 0 then may want to make an adjustment. If not then AFR targets are as mapped within the BEF. Is there a link to your specific log with the "problem" you want me to look at?
Thanks for your reply Terry, however i wish it was that simple
If you look at row 19-21 in log with BEF the AFR "spikes" and at the same time the TRIMS are hitting 10-11. AFter that event the trims decrease and so does the AFR slowly.
Since ive only checked a few logs and ive only seen this in one, i guess this could be an isolated event.
But according to you the maximum value of 50 in the JB4 logs, for trim, has not changed regardless of stock flash och BEF?
I'm trying to understand what has changed since in the BEF's since i will help a friend with a custom map 6 once we flashed his car with your race-BEF..
Car: 2010 e61 n54
05-02-2018, 06:31 PM
For those of us who run the JB4 CANbus wires to the harness behind the OBD port instead of using the BMS OBD connector, is it sufficient to put the JB4 on map 0 to flash? or do we need to remove the JB4 CANbus wires completely every time we want to flash a new BEF map. I have the two canbus wires positapped to the grey/blue OBD wires directly, as I know many others do.
*EDIT*: realized that MHD can't communicate with the ECU while the CANbus wires are connected. Added an in-line dual throw switch for quick-disconnect of the JB4 wires when flashing by BEF with MHD.
Reason: update
Car: 2013 F30 335i
05-03-2018, 08:05 AM
Hey guys, I got MHD yesterday and installed the pwg3_race3 map and im running pwg11 on my JB4
This morning I got the following codes:
1221
0818
0001
I have 2 questions, what do these codes mean and also what is the difference between pwg3_race3 and pwg3_race3b?
05-03-2018, 09:51 AM
1221
0818
0001
Select F series before reading codes, the higher the number/letter the newer the map.
Car: 2015 m235xi
05-05-2018, 08:37 AM
If you are running just a OTS map does the JB4 have to be removed completely from the car or can you put it on Map 0 and unplug it from the OBD port? Thanks.
Car: 535i GT
05-05-2018, 02:44 PM
Any help guys. Trying BEF for the first time today. Getting codes:
121002 Map sensor short to ground
123002 waste gate control short circuit to ground
120408 reduced power mode
Any ideas where I can start troubleshooting? Reflashed to Map0 then reloaded the BEF.
firmware is latest iso10 T13.
Car: 535i GT
05-05-2018, 03:12 PM
Sounds like an issue with boost solenoid circuit, maybe damaged board cutting diode wrong.
Car: m1235 2013 f20 n55
05-06-2018, 03:39 PM
hi terry i flashed pwg3_race3c
i have problem with afr and fph
ign very bad too
what i can do ?
thx
 m135 2013 at-8 PWG STG2 PureTurbo DP-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
05-06-2018, 05:06 PM
If FP_H is faulty you need to determine why. Did you touch the low pressure system?
05-06-2018, 10:18 PM
I have fh_l stg 2 from fuel-it
Car: M135i 2014 EWG JB4 MAP 2 + MHD BEF *****
05-08-2018, 11:49 AM
Hi there recently done the mhd backflash following the steps provided
Just to confirm i was right in unplugging jb4 which is on map 2 ,fashing the stage 0 first then flashing the correct BEF from you list (ewg pump.8) once flashed replugg the jb4 back in and map2 , set futureused bit 6 on job done ?
Also added the cold start delete option what the opinions on this with *****, my car seems to run a little rough when first started now i have added this option
05-08-2018, 12:07 PM
The order of operations doesn't matter. Cold start disabling can have side effects. If you dislike them then turn it back on.
05-08-2018, 12:39 PM
Thanks for quick response terry  think i will do
Car: BMW M135I
05-08-2018, 01:06 PM
Pushing this up since it never got replied, hoping that Terry will spot it this time
05-08-2018, 06:12 PM
Fuel trim is just one value based on JB4 settings, flash settings, including boost targets, air/fuel ratio targets, etc. If fuel trims are exceeding say 45 the you need to rescale them by raising open loop in the JB4. If open loop is already at 70, then you will need to adjust the fuel scalar settings in the BEF directly.
Car: BMW F20 m135i
Bmw m2 + MHD pump fuel BEF and JB4 on 98/99RON pump gas -
05-10-2018, 02:37 AM
Anyone running this set up ?
If so, how is it ?
F20 M135i EB AT with options - what a hoot !
Car: 2010 e61 n54
05-11-2018, 03:17 PM
Any chance we will see a PWG1_E85 back end flash added?
Currently getting some burbles / shaking / jerking at high RPMS while running e20 with the pump BEF and the latest ISO on my FBO pwg f30. Avg_Ign higher than I'd like at around 6.5 and not sure why.
05-11-2018, 04:38 PM
Just email us for it for now.
Car: 2012 f30 335i
05-13-2018, 09:22 AM
Is it possible to get a pwg3 pump gas map?
N55 powerd 335I sedan  :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
05-13-2018, 09:25 AM
+1
05-13-2018, 02:33 PM
Hi, new to this done a short log the other day on the jb4 bef pump , noticed my throttle reading 102% is this normal... thanks
05-13-2018, 07:55 PM
EWG, RACE bef.
Log
long pull to ~155 mph
05-13-2018, 09:41 PM
Originally Posted by 135idct
EWG, RACE bef.
Log
Looks really healthy to me!
