(#526)
TideMD's Avatar
TideMD TideMD is offline
Car: 2016 M4
Default 04-15-2018, 10:52 AM
Looks good. What do you think of map5 vs. say map2 behind the wheel?
Riding with map2 the last several days and I feel like the JB4+BEF stack is WAY more drivable than the standalone JB4 map2.
There's still a sudden dump of torque at around 4k RPM that will throw your head and butt into the seat, and can suddenly swing the backend sideways if not ready for it.
However, low RPM range is much smoother and is actually usable for daily use.
Boost levels don't taper to the pressure level of map5, but I'm assuming that's set by the map parameters.
Posted a couple of logs and will upload some more over the coming days and should get to an area with E85 next weekend. Looking forward to trying out various blends.
Originally Posted by Snowman
For you who run BMS bef stacked with JB4, what are the biggest ups with running that combo compared to just JB4?
I had a M135 last year with "just" JB4 and i thought that was mental with a properly set up map 6
Now im curious on what might have changed and in what way the bef could improve the drive.
Would it be possible to have a log on any map, with and without the bef to see what has changed?
I installed the JB4 a few months after delivery of my M4 and drove it for almost 2 years before the MHD beta and adding the BMS BEF. In my opinion (and without objective data such as dyno numbers), you can't even compare the JB4 on its own. Adding the BEF makes the power delivery unbelievably smoother and the individualized tweaks that Terry provides for each driver/car set up is top notch.
Add in the MHD flash options (burble, VMAX delete, etc, and more to come...), and the entire system becomes an even greater pleasure to drive. I can't help but smile every time I'm on the road and enjoying a nice leisurely drive, then decide to put the foot down and get that rush of raw power.
2016 F82 M4 / Sakhir Orange / Black extended leather / Opti-Coat Pro
NGK 1-step colder, 0.020" / BMC drop-in, carbon delete / Injen intake & CPs / AR Design catt'd down / AA mid
LCI rear light retrofit / AutoTecknic front splitters / Mode Carbon High Kick rear spoiler / 3D Design rear diffuser
Michelin Pilot Sport 4S 265/285 35-19 / BMS ceramic black exhaust tips / Macht Schnell spacers - 15mm(f), 12mm(r)
Abear Abear is offline
Default 04-16-2018, 07:10 AM
Car feels super strong. To me, the logs look pretty good, trims dip for a bit in 4th gear, but honestly, besides doing logs, the car is not really in the rpm range for very long where it dips.
Just posting to see what you think.
siim138's Avatar
siim138 siim138 is offline
Car: F10 535i
Default 04-16-2018, 07:17 AM
Originally Posted by siim138
Hello,
since the MHD Beta release at 11. April I'm on the way with my JB4 with BMS BEF (PWG1_RACE_1c.)
Power is so smooth and fun to drive, burble ist just amazing also. Map 1 feels the best to me. Amazing job guys!
A little negative side: last night a was abel to drive a little faster and make the pulls like 0-100 MPH - I got 2 times drivetrain errors No reduced power just error kicks in at 90 MPH when I'am in WOT without letting down the pedal...I made a quick MHD read out for DME codes, you can see them on the pic.
I made some pulls later, then no drivetrain error.
With JB4 Map 1 only (over a year since today, I never got this error when driving the car in the same way)
Today I'm able to make some logs with my JB4 and then post them here!
Here are the logs, 3th gear pull and 4th gear pull and the last 0-200km/h (125mp/h). ONLY one time I was abel to get the same drive train error, unfortunately I was not logging at this time. I straight cleared the codes with ISTA and then made several over 0-110MPH and 40-110MPH pulls and somehow no drive train error JB4 is up to date to latest FW (for BEF) and all settings are default. Need I change anything in options?
2011 F10 535i M-Sport PWG // Deep sea blue //
//JB4 PWG_INT_13 + BMS BEF PWG1_RACE_3 // M Performance mufflers// 3,5" cless dowpipe
Default 04-16-2018, 08:23 AM
You need to update to PWG ISO firmware to use a BEF, and may need slow speed CANbus.
Default 04-16-2018, 05:15 PM
Hi, sorry I'm a real beginner here.
For PWG ISO help use the PWG ISO thread in this forum.
Nbarrett Nbarrett is offline
Car: 2014 435i Xdrive
Default 04-16-2018, 05:25 PM
Can anyone give me some insight on the BEF instructions? do i just follow the original first page directions? I'm wondering which BEF map is best for my car. does the MHD app walk you through everything I'm just not finding good instructions for doing this BEF. also after all said and done which MAP do you run the JB4 on?
2014 EWG F32 435 Xdrive 6MT_93 Octane Pump Fuel
JB4|Dinan Intake|VRSF 4"|ER FMIC&Charge Pipe|
Default 04-16-2018, 06:21 PM
Directions are in the first post. The fuel used depends on the intended fuel usage. Always E85 mix, always pump, switching between the two, WMI or not, etc.
Default 04-16-2018, 06:25 PM
I'm always93 octane pump until i do WMI or E85. for 93 octane would i use the Race or Pump BEF?
Default 04-16-2018, 06:39 PM
I'm just confused so i download the MHD app unplug my JB4 OBD plug and hookup my MDH Flasher and flash stage0 for whatever the MHD cost. after this do i go back to jb4 to select a tune or leave it on whatever map because it seems as though the directions say to go back to jb4 and set the Future Use D to Bit 6. then go back to the MHD and download then load the appropriate BEF.
this is my first time doing this so sorry for being a noob
Default 04-16-2018, 07:38 PM
Start with RACE
m4driver m4driver is offline
Car: M4 2015
Default 04-16-2018, 10:33 PM
just tested the actual BEF E85 map for the S55.
Anyone else having "problems" with the burble option? The burble only works the first few minutes after starting the engine. When I push the car the burbles won't get back until stopping and starting the engine again. Also having this problem with the normal RACING BEF map for the S55. It seems to be not dependent on the burble intensity or duration.
Bye
siim138's Avatar
Car: F10 535i
Default 04-17-2018, 01:39 AM
Hi, I posted my problem there.
Could you Terry please tell me here:
Is there no chance to use regular (no ISO) JB4 with BEF? Somehow my car operated well with it! Never felt so smooth and strong power.
After one year usage of regular JB4 I never need slow canbus, do I need now change the settings for canbus?
P.S's Avatar
P.S P.S is offline
Car: M135i xDrive
Default 04-17-2018, 08:54 AM
Fix the fuel pressure with PI volume and I can help you fix the fuel trims after.
First impression of PI tune is pretty good. Trying to get some 1/4 mile logs and email them.
M135i xDrive EWG, JB4, Pure S2, Pure inlet, N20 tmap, c a tless, Wagner fmic, FTP chargepipe, Fuel-it PI, BMS PI controller, Fuel-it lpfp, ACF Performance back end flash. 10.9s @ 204km/h
P.S's Avatar
P.S P.S is offline
Car: M135i xDrive
Default 04-17-2018, 10:27 AM
Not too bad from standing start either.
CT_Drifter's Avatar
CT_Drifter CT_Drifter is offline
Car: 14' F30 335i EWG N55
Default 04-17-2018, 11:19 AM
Start with RACE
I run 93 octane and 100% meth, I should be using RACE BEF?
Timdelacerna Timdelacerna is offline
Car: 2014 f30 335i
Default 04-17-2018, 11:53 AM
I successfully flashed stage 0 but could not flash the jb4 backend flashes to the vehicle. It states FILE NOT COMPATIBLE with this car 00002a471daa03 vs 000021571d8202
Does that mean I need a custom backend file for my car??
Default 04-17-2018, 02:35 PM
so after everything is flashed does the JB4 function as normal with options for multiple maps based on PSI gains or is there a certain map that we should use to utilize the BEF?
Car: M4 2015
Default 04-18-2018, 01:58 AM
Bye
MHD is working / testing on that burble issue, they released a beta version yesterday: 0.993b.
tcabill tcabill is offline
Car: 2012 535 M Sport
Default Keeps getting better PWG1 - 04-18-2018, 04:47 AM
Had a few problems at first but is was due to not running updated ISO firmware. I am definitely seeing the need for my next mod, a F M I C, more boost equals more heat. I have posted a few logs for review.
2012 535i M-Sport, VRSF Chargepipe, BAVAUTO Hi Perf Coils, NGK 95770 plugs (colder),GFB DV+, VRSF 3.5" **, Wagner FMIC, MHD Map E30 2+, Walbro 450 with 3/8" fuel lines from tank to HPFP with inline Ethanol sensor (all self fabricated).
suchtragedy's Avatar
suchtragedy suchtragedy is offline
Car: 2013 335i
Default 04-18-2018, 08:39 AM
Caution, potential bug in MHD 0.993b, see below.
4/18/18: I just loaded MHD 0.993b stock map0 that came out today (update with N20 TMAP flash option) and now getting permanent drivetrain malfunction (reduced power) mode code that won't clear. Steps used below:
1. Flashed MHD BEF 0.993b stock map0 (burble, limiter removed, and N20 TMAP checked)
2. Reflashed JB4 BEF PWG2 Race4c
3. Reconnected JB4 (running ISO10_T13 firmware) and turned on the car
4. Immediately got drivetrain malfunction, attempted to clear via JB4 but immediately came back up. Shut car engine off.
5. Suspected N20 option needed disabled in JB4 so disabled N20 in JB4 settings.
6. Restarted car, drivetrain error gone.
7. Drive 5 minutes, as soon as I got into boost drivetrain error returned, unable to clear same as before.
At this point I repeat the same steps, but this time when I flash 0.993b stock map0 in MHD I uncheck the N20 TMAP option.
1. Reflash MHD 0.993b, uncheck N20 TMAP
2. Reflash PWG2 Race4c BEF
3. Reconnect JB4, check N20 TMAP option
4. Restart car, drivetrain malfunction persists.
So FYI seems there is a potential bug with the new 0.993b firmware, at least with my car. I have 2013 F30 335i PWG.
2013 F30 N55 PWG | PS2 | FBO | JB4+MHD BEF | JB4 PI Controller w/ WMPI | Stg2 LPFP | xHP Stg3 | MFactory LSD
Default 04-18-2018, 10:10 AM
There should be no TMAP sensor options in "load a back end" flashing option....
Car: 2013 335i
Default 04-18-2018, 10:30 AM
You are correct, however the checkbox is available as a flash option for stock flash in 0.993b. I flashed this with N20 TMAP checked, then flashed BEF PWG2 Race4c and the checkbox shows grayed out in the BEF options, but while grayed out it shows option still checked from when I flashed the stock MHD flash in 0.993b. I hope that makes sense.
Car: 2013 335i
Default 04-18-2018, 05:51 PM
Got off work today and car started and issue gone. I still think the double N20 enabled option both in MHD and JB4 caused the error and undoing it in MHD reversed the issue I had but maybe I just needed to wait for DME to fully power down or something? I don't know guys but anyway things working again for now.
Dspeed23 Dspeed23 is offline
Car: 2015 m235xi
Default 04-19-2018, 09:30 PM
Just out of pure curiosity, how does MHD’s OTS stage 1,2 & 2+/E85 maps compare to BMS BEF pump, race & E85 maps in hp/tq numbers on FBO F series.
PSIcho's Avatar
PSIcho PSIcho is offline
Car: BMW 435i
Default 04-20-2018, 11:42 AM
Tried flashing BEF today using the new MHD v. 99c and got a "Coding could not be read..." message. Have been flashing BEF since the beginning, and every MHD update with no issues... Anybody else had encountered this?
2014 435i EWG N55 - BMS Intake - VRSF CP & 5'' HD FMIC - 4'' CLess DnPp - JB4 - E30
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
