Car: 2012 BMW 135i
10-20-2017, 06:56 PM
Hello guys. I was trying to load BEF today and I couldn’t pay 199$ for it. The payment just wasn’t going through. Does anyone had the same problem as me?
Car: 2012 BMW E92 335i M-Sport
10-20-2017, 10:53 PM
That’s more of a Google issue than MHD. You probably have a new google account and that’s why it’s not excepting the payment.
12’ E92 335i 6AT - Alpine White M-Sports Package
Mods - | JB4 ISO | BMS Pump BEF | BMS Intake | VRSF Kittenless D0wnpipe | VRSF CP | VRSF 7” FMIC | Alpina Flash | Euro Headlight Switch | Avant Garde M359 | Michelin PSS
Car: 07 335i AT
10-21-2017, 08:34 AM
We currently experience issues with Google being too aggressive at filtering out fraudulent payments.
Here you can request a call from Google, other customers revolved this issue quickly with a call, use the "Get help" button at the bottom:
https://support.google.com/googleplay/answer/1267137
Alternatively, you can get Google Play cards to make your purchases.
Purchase rejection is most of the time it is due to
- your google account being new
- your payment method that was not so far used with Google (or since a long time).
- using your account to pay on several devices.
That restriction from Google is often cleared after some days but a call from Google is much quicker.
Car: 2012 BMW 135i
10-21-2017, 08:45 AM
Thank you. I’ll try again today or tomorrow.
Car: 2012 BMW 135i
10-22-2017, 09:54 AM
Hey guys. I finally installed MHD BEF in my car. Everything is fine but one thing. I have
c a t l e s s d o w n p I p e s and my check engine light is on. Can you tell me why? I didn’t check the box where it says oem down pipe.
10-22-2017, 10:47 AM
Are you sure the CEL is from catalyst efficiency?
Car: 2012 BMW 135i
10-22-2017, 12:58 PM
I’m pretty sure. I didn’t have it before. I installed ********* on Friday and the light came on and next day I installed MHD BEF.
Car: 2011 BMW 335i
10-22-2017, 01:09 PM
You have to disable the code in TunerPro.
2011 335i / MHD E85 BEF / JB4 ISO / xHP Stage 3 TCU / M3 Control Arms / VRSF Piping/ Phoenix CP / YCW Coilovers 6K-18K / Enkei Raijin 18' Wheels / Michellin PSS
Car: 2012 BMW 135i
10-22-2017, 01:18 PM
What is TunerPro?
Car: 2012 BMW 135i
10-22-2017, 01:36 PM
I thought MHD flash should take care of that.
Car: 2011 BMW 335i
10-22-2017, 02:16 PM
TunerPro is mentioned in first post. MHD is just the name of program you use to flash. The MHD maps you pay for have the *** code disabled in the .bin
The maps Terry made do not have them disabled. Very easy to do on your own though.
Car: 2012 BMW 135i
10-22-2017, 03:38 PM
So can you tell me how can I disable the light?
Car: 2011 BMW 335i
10-22-2017, 03:53 PM
I'll PM you.
Car: 2012 BMW 135i
10-25-2017, 12:21 PM
Hey guys. Need a little help here. Does any one know how to install TunerPro to fix CEL light from my C A T L E S S D P? Or maybe be some other way?
I have 2012 135i with MHD BEF and jb4.
Car: 2011 BMW 335i
10-25-2017, 12:29 PM
I already told you. You're getting 2D11, which has to do with O2 sensor and 36BE which is a coding issue. Probably can just clear that one. Or use NCSexpert to fix 36BE.
3106 is the code to toggle for ** as far as I know.
Car: 2012 BMW 135i
10-25-2017, 01:04 PM
I know. I’ll fix the sensor but D P code came out too.
Car: 2012 BMW 135i
10-25-2017, 01:07 PM
I meant to say I fixed the sensor.
Car: 2012 BMW 335i N55
10-28-2017, 12:59 PM
I have a 2012 335i LCI E92 N55..... do I still have to flash the DME before doing the MHD flash ? How do i go about doing so if I have to ?
10-30-2017, 08:33 AM
From MHD’s FAQ:
go to http://www.realoem.com/bmw/enUS/select and enter the last 7 digits of your VIN in serial number. Click Browse parts the ENGINE ELECTRICAL SYSTEM and check both CONTROL UNITS > MEVD1726 section. If it says "No parts found matching your car." you have a MEVD172 which is directly flashable.
If you end up having an MEVD1726, then you will need to have your DME removed and sent out to be unlocked.
Car: 07 335i AT
MHd upate 1.24 -
11-13-2017, 02:48 PM
1.24
- Added heartbeat signals while flashing to keep other ECUs in the car happy.
- Added Torque limiters 1-2-3 log channels.
Adding the torque limiter channels confirmed what we noticed with logs that the late E series (1726 DME) have more limiters than early n55 (172 DME). We're working on those extra limiters.
Car: 12' 135i
11-13-2017, 03:48 PM
Originally Posted by MHD
1.24
Any idea when boost by gear and on the fly map switching is coming?
18’ Glacier white RS3
#PURETURBOS
#FUELIT
Car: 335i 6MT RWD
11-14-2017, 04:51 AM
Or Bluetooth.
Car: 11 135i
11-17-2017, 01:34 PM
Or a launch option
11-17-2017, 01:57 PM
It's been here since 2010 for the N55... Just need a JB4 installed to activate.
Car: 07 335i AT
11-23-2017, 07:13 AM
Map switching is being tested on an actual car.
Originally Posted by KevinC39
Or Bluetooth.
We had to restart twice from scratch for various reasons.
Originally Posted by Stoolz
Or a launch option ��
We'll try to adapt the F series launch.
That would get you boost curve switching. The DME maps switching is interpolating boost, but also timing, fueling, load etc. Also, 2 maps can be blended 0 to 100% with a slider on the fly.
