terrik terrik is offline
Car: 2018 M240i
Default M240 JB4 Log Review - 09-16-2019, 10:33 AM
Hi all,
I have a 2018 M240 with a Dinan midpipe, BMS cold air intake, and jb4 as my only mods. I run map 2 currently, and was hoping someone can check my logs to verify everything looks fine? Planning on getting a down-pipe soon, hopefully if they go on sale for the holidays. Then hoping its safe to switch to map 3.
Also, if anyone wants to give a brief overview of what I should be looking for in these logs to verify good performance, or a link to a thread with that info...I'd be more than happy to learn to fish myself.
B58_M240 B58_M240 is offline
Car: M240i
Default 10-04-2019, 09:08 AM
terrik: Switch to MAP1 and post a log in 3rd gear from 2.5K - Redline, making sure you keep the pedal to the floor. Folks will help you from there. Also, if you have EWG or FF wires connected, be sure to include that in your reply. Be sure you read through all the threads for information related specifically to the setup on the M240i.
Car: 2018 M240i
Default 10-06-2019, 05:53 AM
Thanks for the advice. I dont have any of the extra wires, so here is map 1 @3rd gear.
I'll dig through the threads in the main forum area to see what I can find.
Car: M240i
Default 10-07-2019, 01:14 PM
In order for us to help, you have to log properly.
Car: 2018 M240i
Default 10-07-2019, 01:24 PM
Okay? The log is at 2.5K RPM in 3rd gear with the pedal down...I hit redline but cant stay on it much or else I'm literally hitting 100+ mph on the highway.
Unless I'm missing something, collecting the data isn't worth the $350+ fine.
Thanks.
Car: M240i
Default 10-07-2019, 01:38 PM
Thanks.
Logs show that pedal / throttle are not at 100%. Try for a smooth and steady climb to near redline.
Also, you might consider upgrading to latest firmware. Name:  MAP_1.jpg
Car: 2018 M240i
Default 10-08-2019, 07:46 AM
I'll see what I can do, thanks.
