Turboh's Avatar
Turboh Turboh is offline
Car: 2017 BMW 340iX
Default Map6 6.0 psi flat review - 07-24-2019, 07:51 AM
Hi
I have tried several time to run Map 6 with 6 psi flat, but it will not add the 6 psi. The runs are as though I am running Map 0 and the WGDC is zero. All my other runs at 5.5 psi and lower are fine. Is there a limit on the additive map on boost, besides the 10 psi cut off?
Please review the attached run.
2017 340iX with M track handling package, 6 speed manual, BMS intake, and JB4 piggyback; EWG and FP wires; 93 octane; and fun with Honda S2000; Ninja Z1000.
JorgeIII JorgeIII is offline
Car: BMW F30 LCI 320i 2017
Default 07-24-2019, 08:40 AM
Hi. Until someone from client support gets into it maybe you can try rolling back to firmare v9.
You might be having the same problems with firmware v11 and upwards I posted here: Problems from firmware v11 (to v13) with absolute maps - N54Tech.com - International Turbo Racing Discussion
Jorge.
Turboh's Avatar
Car: 2017 BMW 340iX
Default 07-26-2019, 07:57 AM
Thank you. I have a similar issue. Version 9 works fine, but version 11 does not.
I have not gone to higher series versions of firmware because I do not want to run into other new issues.
