JorgeIII JorgeIII is offline
Car: BMW F30 LCI 320i 2017
Default Problems from firmware v11 (to v13) with absolute maps - 07-23-2019, 08:54 PM
Hellow. I need some helps with latest firmwares.
v9 firmware worked fine using MAP6 with absolute 16/17 PSI.
I tried firmwares versions 11 to 13 with the same user settings than with v9 and Im not getting boost, every time I tried I finished going back to v9, tried again yesterday with firmware v13.1.
Can someone tell me what Im doing wrong?
Here is a file with yesterday logs with firmware v9 and v13.
The Logs (7 WOT runs, same day) are one after the other in the same file.
Log 1: Firmware v9. WGDC and FF too low, tappered down Duty bias.
Log 2: Firmware v9. WGDC up but FF low, ajusted it up.
Log 3: Firmware v9: little Over boost and timing drops, ajusted FF curve from duty bias (very little) and PID gain.
Logs 4 and 5: v9. Some ajustments in FF, FF curve, FUA and PID gain
Log 7: First wot run with Firmware v13.1. No Boost, basic values as WGDC and FF missing. Whats going on with v13??? I got similar problems with v11 and v12.
Thanks. Jorge
Engine is a B48, 20i, 11:1 compression. Stock. Fuel: Shell VPower RON 98.
File Type: csv 2019-07-22 18_11_54 (b48 20i 16psi flat)_Map-6.csv (89.3 KB, 22 views)
