LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default Log review - map 5 - 08-27-2019, 09:24 AM
Logged some runs on map 5 and E25 mix.
I mixed in E25 and started on map 3 and FOL = 45, to map 4 and FOL = 50, and end with runs on map 5 and FOL = 55.
Seems like Im having to set my FOL higher than other users to keep trims (and AFR) in line. Curious if i should be concerned by that?
Two logs attached for map 5 runs, first showing trims maxing a bit on FOL = 50, and a second with only change being FOL = 55.
I think the logs look healthy but want to make sure the settings and log seem ok.
2017 AMG C63 -JB4
2009 535i - 548whp - sold
ezatnova's Avatar
ezatnova ezatnova is offline
Car: 335i Coupe
Default 08-31-2019, 05:30 AM
Maybe they only check the sticky thread??
Default 08-31-2019, 06:13 PM
Setting FOL higher will eventually result in fuel pressure fault codes, but the log itself looks fine to me.
LessIsMore's Avatar
Inner Circle Member
Default 09-08-2019, 04:55 PM
Thanks Terry.
Actually yesterday I did receive a 0087 code for fuel pressure ( Was not logging at the time unfortunately). I ran Map 5 with E25 for weeks with no trouble. I do recall another post of yours saying that high FOL could cause a fuel pressure code but since I had no idea what range is "high" and hadnt gotten an error after so long, I thought I was in the clear.
I tried clearing the code with the JB4 and it would not! But after a few restarts it went away on its own thankfully.
I backed the FOL down from 55 to 50 and stepped down to map 4. So far so good. Going to try that for a couple days look at logs and go from there.
2017 AMG C63 -JB4
LessIsMore's Avatar
Inner Circle Member
Default 09-11-2019, 08:15 PM
Update: did some map 4 logs, look ok to me but welcome any input.
2017 AMG C63 -JB4
Default 09-12-2019, 06:09 PM
Looks fine to me here.
LessIsMore's Avatar
Inner Circle Member
Default 10-05-2019, 09:58 PM
Thanks Terry, pardon delay in replying.
I have been running map 5 with the FOL at 45-50 for the last couple of weeks and have not had another code.
2017 AMG C63 -JB4
