jadeite22 jadeite22 is offline
Car: mini f56 2016
Default Any issue with my jb4 ? - 09-10-2019, 07:54 PM
Hi Terry,
havn't turned on my BT in a while but I've noticed change in screen and the RPM is not showing anything. i was on MAP 1 and nothing has been touched since installation.. or at least to my knowledge.
also engine light came on after hard accel.. i'm thinking it was due to boost limit change right before driving.. not sure .
Only recent installation was pedal master on existing mods.
Should I be concerned ? thank you in advance.
also quick question about in dash mode on boost limiter - it says limit cap is at 3 and when i try adjusting, tachometer on left increase in very small increment going all the way up to 7 .. is that what it supposed to be ? and I assume it should not go beyond 3 ?
Default Today, 08:23 PM
If RPM isn't showing normally that indicates an issue with the OBDII cable
