(#2626)
Jays_stinger Jays_stinger is offline
Car: Kia Stinger GT
Default 09-16-2019, 11:40 AM
Here is a datalog at idle then a small short distance drive.
Everything look ok?
Thanks Terry.
Default 09-16-2019, 12:01 PM
Everything look ok?
Thanks Terry.
Unless you are trying to diagnose some specific issue any non-WOT log isn't going to be useful for providing you tuning advice.
Good Morning Terry,
Would you be able to tell if a spark plug is bad from a data log(Parked while iding)? I seem to feel and see the motor vibrating. Doesn't seem right to me..
No we won't be able to. Poor idle is usually a vacuum leak. If a plug was bad you'd get misfire codes.
Default 09-16-2019, 12:02 PM
Originally Posted by rboettcher81
Did a few passes earlier this week. Car feels great. Launch control with the diff bracket on Map 2, even with all that torque still rips with very little wheel spin (RWD Stinger here).
I'm not sure what the ignition timing is supposed to be @ WOT but everything else seems ok I think?
Looks normal to me.
Marcoracing1 Marcoracing1 is offline
Car: Genesis G70 3.3t Sport AWD
Default Map#5 - 09-17-2019, 06:14 PM
I Terry,
Do you think I can try map # 5 if I use 94 octane gas + boostane to increase octane up to 105...there is no ethanol 85 in canada?
can I damage something or the system is going to to protect himself???
Default 09-17-2019, 06:29 PM
Yes that should be ok. Not likely to damage anything but when it comes to tuning more boost more risk all else being equal.
Default 09-17-2019, 06:43 PM
it's only for one or two 1/4 mile races ... I made a bet with a friend and he does not believe that a Genesis G70 can roll down 12 seconds and I miss him almost nothing with a time of 12.04 in map # 3 ... after having my little piece of paper I return to map # 2 which is very satisfactory!
rboettcher81's Avatar
rboettcher81 rboettcher81 is offline
Car: 2019 Kia Stinger GT
Default 09-18-2019, 05:29 AM
Looks normal to me.
Thanks Terry.
Default 09-18-2019, 10:58 AM
Stinger-Performance Stinger-Performance is offline
Car: Kia Stinger
Default 09-19-2019, 01:08 AM
I just got my JB4 with fuel wires installed on my AWD GT, only mods are a DIY CAI and Denso plugs at .022 gap. I'm limited to 91 octane fuel.
Same section of road and IAT was 96 deg and 75 deg ambient at the start of each pull to try to minimize variables.
I need to figure out how to view these logs in graphical form on my laptop but haven't researched it yet.
Attached are two logs, Map 0 and Map 1 0-100 mph with launch control. It didn't feel like as big of a gain as I was expecting after reading everyone's reviews so I'm hoping you can look over the logs and see if everything looks correct.
What I'm curious about is:
-Is it required to engine off/engine on after changing maps to get the change to "take"?
-Whether 10-12 psi is normal for stock/map 0?
-Whether it looks like I'm getting the right amount of added boost with map 1? Seems a little low to me (13-13.5 psi average?).
Whether it looks like I can try map 2? To me it doesn't look like it's detecting knock currently but I could be wrong.
Thanks for your time.
MurlinatoR's Avatar
MurlinatoR MurlinatoR is offline
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default Yesterday, 10:40 AM
-No. You can change maps while driving.
-Yes. Factory tuning is limited to 12psi peak.
-Yes. I believe each map adds approximately 2 psi.
-Yes. 91 octane is fine for map 2 and could work for 3 possibly.
-MurlinatoR
Connoisseur of all things Kia
Car: Kia Stinger
Default Yesterday, 10:47 AM
Thanks. Mine doesn't seem to take the map change until a power cycle. I put it in valet mode to verify and it stayed there until I turned it off and back on. Searched around and found no mention of needing to do this, hence the question.
Hoping Terry will look at my logs.
Adamdan Adamdan is offline
Car: Stinger
Default Yesterday, 11:02 AM
I would wait for terry to give the ok for your map 1 then try out map 2 on 91. I would never even try to run map 3 on 91 without a good octane booster or adding e85.
Default Yesterday, 12:21 PM
Map1 looks ok. You can log map2 for comparison.
Car: Kia Stinger
Default Today, 12:18 AM
Is there a way to log time in seconds with the ECU's real-time clock so datalogs can be used to precisely extract 0-60 or 0-100 times?
Here are two 0-100 pulls on map 2 with 91 octane, let me know what you see. Thanks.
Default Today, 08:33 AM
The speed reading isn't accurate enough for anything other than 0-60mph estimates which the JB4 mobile app provides. Get a GPS based dragy off our site for reliable performance metrics.
On map2 still some timing movement but I think it's probably OK. Sort of par for the course for 91 octane. If you limit the tuning to perfect timing you may have to detune from factory.
Car: Kia Stinger
Default Today, 10:44 AM
Thanks, I'll use MAP 1 most of the time and just go to MAP 2 if at the track or something and it's not too hot out. I plan to use an E30 mix in the future to try higher MAPS.
Three Questions:
-Is there a post-intercooler air temp sensor on these cars? If so what channel is it in the datalog?
-Does the Stinger have enough fuel flow capacity and closed loop AFR tune adjustability to run straight E85 if on MAP0 (to save my wife money when she's driving it since E85 is about $0.80 less per gallon than 91)?
-Are you aware of anyone putting an AWD Stinger on a 2WD dyno with the AWD fuse removed? I'm wanting to do so but I'm not sure if it will act weird if it doesn't get a front tire speed reading and thinks it's a burnout or something.
Default Today, 02:44 PM
IAT is post intercooler on the manifold.
No you can't run more than E30-E40 before the high fuel pressure pump can no longer keep up at higher boost levels.
On disabling AWD for dyno don't know much about it sorry. It's been tried but I don't have details or know if it worked right.
PcChip PcChip is offline
Car: Veloster N
Default Veloster N - JB4 log - Today, 05:31 PM
Hi Terry,
Just got my JB4 installed and recorded a third-gear pull (very slightly uphill)
Ambient temp was 93F
Forge Turbo Inlet
Forge Intake
JB4 (latest firmware) - Map2
Look okay?
any tweaks we could do?
