(#276)
jrobohm's Avatar
jrobohm jrobohm is offline
Default 09-01-2019, 06:21 AM
Originally Posted by Q50Philly
I wanted nozzles with filters, as one of my BM5 nozzles was completely blocked. Strange since theres a filter connected to the solenoid. Regardless..just protecting my engine with the ProMeth nozzles. The bonus was a much finer mist compared to the BM5s.
Finer mist - sounds good - what has your butt dyno and logs said about the switch in nozzles ?
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8s
  • AMS HE w/ Aux Tank
  • AMS LDP
  • FI Res CBE
Default 09-03-2019, 09:50 AM
Usually a lower flow rate because of that. Finer mist = less flow volume.
Q50Philly's Avatar
Q50Philly Q50Philly is offline
Car: 2018 Infiniti Q50 Red Sport
Default 09-04-2019, 05:57 AM
I would have thought that, but both are rated at 5gph.
2018 Q50 Red Sport AWD
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
AMS Red Alpha Cold Air Intakes
Megan Racing LDP
Tanabe Y-Pipe
Mishimoto Oil Catch Can
jrobohm's Avatar
Default 09-10-2019, 08:47 AM
Bump - just got my PM7’s - I’ll install them and compare - Q50Philly - How have your results been?
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8s
  • AMS LDP
  • FI Res CBE
jrobohm's Avatar
Default 09-10-2019, 04:42 PM
Installed the PM7s - the BM7s still look brand new. Quick log share attached. Need to do a real pull but honestly I do not feel a difference with the butt dyno.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8s
  • AMS LDP
  • FI Res CBE
Car: q50
Default 09-11-2019, 06:00 AM
Looks very reasonable.
Q50 Premium RWD
BMS JB4 w/ FW & WMI
Post turbo stuff lol, Y pipe, Mid pipe
BMS HE
Default 09-11-2019, 02:08 PM
I'd expect trims to be a little lower under WMI flow.. Sure it's flowing properly? Do a test purge to ensure a clean spray out of the nozzles?
jrobohm's Avatar
Default 09-11-2019, 02:24 PM
Ok - I’ll pull the nozzles and do a purge into a measured container, record each bank, and post the results.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8s
  • AMS LDP
  • FI Res CBE
Default 09-12-2019, 06:30 PM
Sounds like a plan
Car: q50
Default 09-14-2019, 06:38 AM
Latest log on map 8 for me. Hot down here so limiting the boost.
Q50 Premium RWD
BMS JB4 w/ FW & WMI
BMS HE
jrobohm's Avatar
Default Yesterday, 11:35 AM
Log from an on-ramp run: 96 / 52% humidity day in NTX & an E20ish fuel blend. Still looking for time to pull the nozzles and measure bank1 & bank2 output.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8s
  • AMS LDP
  • FI Res CBE
Q50Philly's Avatar
Default Yesterday, 02:23 PM
Really happy with the PM5’s...butt Dyno better! Just today, I added E85 @ 30% to 93...for the first time. WMI+E30 = OMG! I might consider PM6 or 7, but happy for now.
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
Megan Racing LDP
Tanabe Y-Pipe
jrobohm's Avatar
Default Yesterday, 03:18 PM
Just pulled the PM7s and swapped with PM8s - measured each bank with 5 Priming cycles. Measures @ 50ml on each bank.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8s
  • AMS LDP
  • FI Res CBE
Q50Philly's Avatar
Default Yesterday, 03:25 PM
Be careful of Quenching...common with too much flow. Had someone tell me to widen gap on plugs to avoid...haven’t done that yet!
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
Megan Racing LDP
Tanabe Y-Pipe
jrobohm's Avatar
Default Yesterday, 04:14 PM
Really happy with the PM5s...butt Dyno better! Just today, I added E85 @ 30% to 93...for the first time. WMI+E30 = OMG! I might consider PM6 or 7, but happy for now.
Welcome to the WMI + E30 = OMG club! Im running a bit lighter E-Blend (@E20) in an attempt to drop my trim numbers. The PM8s and a E20ish blend moments ago yielded the attached log for comments. For the first time I am seeing trim numbers in the 30s vs 40s so the added Meth flow of the PM8s and slightly lower E content combo seem to be working towards that goal.
On a related question - with the Fuel Wires enabled - is the AFR goal mid 12s? Here is my ignorance showing - on a FI engine, is a richer AFR (11s) safer than mid/low 12s? What are the trade offs?
BMS WMI
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8s
  • AMS LDP
  • FI Res CBE
