Gussy Gussy is offline
Car: Bmw x2
Unhappy Engine light after jb4 install - 07-30-2019, 12:36 PM
So Iíve installed my jb4 bonnet open close doors lock the car put the keys far from the car and waited 10 minuets then I installed my jb4 everything was fine for about 50 miles then the engine light comes on but the cars driving normal so I cleared the fault code but it keeps coming back Iím so confused? The car is a x2 2.0i (b48)
101F01 Throttle valve opening angle pressure -- Ignore, tuner code
104302 absolute pressure sensor, intake manifold, plausibility, caster: pressure too low
101F02 throttle angle - intake manifold pressure, correlation: limit exceeded
These are the codes that keep coming back
Car: Bmw x2
Default 08-07-2019, 08:30 AM
Someone must know
Default 08-07-2019, 10:26 AM
Sounds like the JB4 has the wrong firmware on it. FWD B48s use the MINI B48 firmware, not the BMW firmware.
Car: Bmw x2
Default 08-07-2019, 05:05 PM
Iíve loaded bmw firmware Iíll try mini firmware hopefully stops my engine light coming on
