135itp 135itp is offline
Car: 08 135i AT
Default X2 b48 8psi at idle m, 36psi while driving - 07-19-2019, 08:39 PM
Hey Guys,
Need some help here. Installed a jb4 on a x2 B46O**. This would be my 4th one between a n54,n55, n63 so Iím familiar with everything pretty well.
No codes but Iím reading 8.8 PSI at idle. Checked connections all ok, wiggled harness- OK. Updated 2 different b48 software from the settings page here with no fix. Not sure what to do. Any help would be greatly appreciated!
Thank you!
Car: 08 135i AT
Default 07-20-2019, 07:48 AM
Updated with mini b46O** software and now I’m getting RPM signal and seems like correct boost level. WOT it will go up to about 22psi. Not sure if this is correct.
Basically running a b46O** engine on an x2 with mini flash...?
From pictures the engine is the same as in the mini. Hard to find info online :/
BMS, help
Default 07-20-2019, 09:11 PM
Actually you can use the latest BMW firmware but with a special setting (WMI/E85 page bit3 on) to invert the boost signal readings.
For logs though need to see the CSV!
Car: 08 135i AT
Default 07-22-2019, 05:47 AM
Logs attached.
Let me know what you think Terry. Thank you. Engine is B46O btw I noted b48 previously
Just to confrim:
- BMW_B48_B58_OBDII_8_T12.hex - is the latest and i should download this?
- use BIT 3 under WMI/E85 page (bit3 - Raise "boost over stock" cap from 10psi to 20psi.)
Currently everything is unplugged and back to stock. I need to arrange an appointment to see the car again so just need all the correct info. Thank you!
Car: 08 135i AT
Default 07-23-2019, 04:48 AM
Bumping up my own thread, would like to try and get this resolved this week client wants the car for the weekend.
Happy to email support too.
thanks guys!
Car: 08 135i AT
Default 07-23-2019, 03:41 PM
Bump ��
Default 07-25-2019, 08:29 AM
Originally Posted by 135itp
Logs attached.
Just to confrim:
Yes, follow those directions.
