e92carlos e92carlos is offline
Car: 2008 335i coupe
Default C63 JB4 Dyno and Logs - 05-11-2019, 05:22 PM
I got a chance to put my C63 on the dyno today. Overall pretty happy with the outcome. See below for logs and dyno sheet.
MAP 0 and 2 runs were done on 93 Octane.
MAP 5 was done on e30.
Best run was 531WHP / 624WTQ
Looking forward to installing intakes whenever they are ready.
Any changes suggested based on my logs ?
Thanks,
Default 05-11-2019, 08:45 PM
Not bad! Have a BCM installed yet on this? That lets us offset the wastegate dutycycle and push boost a little higher.
Default 05-11-2019, 08:50 PM
No BCM yet, how much more much can the stock turbos put out?
Can it break 600’s on stock turbos and fueling?
Default 05-13-2019, 10:23 AM
Just emailed you, looks good!
Default 05-13-2019, 10:32 AM
Thank you sir.
BimmerFan BimmerFan is offline
Car: 2014 335i M-Sport
Default 05-14-2019, 09:26 AM
That's nice. What is BCM?
Edit: Never mind. Boost Control Module. It says it's not available yet on the Website and no installation instructions for it. Thanks.
2018 C63s AMG
Default 05-14-2019, 09:29 AM
Thanks,
Boost control module.
Default 05-14-2019, 10:49 AM
We have about x10 of them out. We'll put it up on the site soon.
That's mostly for people with larger turbos, methanol, or running racegas and want every bit of power they can get
Default 05-14-2019, 01:44 PM
Roger that!
2018 C63s AMG
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 08-27-2019, 09:56 AM
Thanks for posting the logs and dyno sheets. Looks great!
Any plans for an intake/filters? Would.love to see before and after with it on map 5.
2017 AMG C63 -JB4
2009 535i - 548whp - sold
Default 09-11-2019, 03:48 PM
Planning to go Pure 900ís soon, so i will probably be selling the Jb4 and going the reflash route.
LessIsMore's Avatar
Inner Circle Member
Default 09-11-2019, 08:10 PM
Why? JB4 works with flash tune. No need to give up the boost by gear, logging, etc. Plus if BMS hold to their promise, next firmware update should have good safety features built in (protect against lean afr, overboost, low fuel pressure, etc.) that flash tunes cant do.
2017 AMG C63 -JB4
Default 09-12-2019, 06:07 PM
Awesome turbos! You're going to still need that JB4 for logging, safety, fine tuning, boost by gear, WMI/PI control, etc, etc!
Default 09-12-2019, 06:08 PM
+1
I've got the latest firmware here if anyone wants to help test it.
ezatnova's Avatar
ezatnova ezatnova is offline
Car: 335i Coupe
Default 09-14-2019, 09:05 AM
+1
Oh man, thatís exciting! Any hints as to whatís in it?
Iím sort of tempted to try it out, but also a bit scared to do so since Iíll be maxing the car out at the roll race tomorrow. If something isnít quite right....not good.
