(#1676)
harizbbjt harizbbjt is offline
Car: Bmw F10 520i
Default 10-12-2018, 05:41 PM
Does it happen on map 0?
yes it does but when I disconnect the jb4 everything is fine.
vkiyko vkiyko is offline
Car: BMW F30 328I 2012
Default 10-16-2018, 03:32 AM
I have the POSI-TAP connectors JB4 N20
my friend have updated my JB4 to the OBD version of firmware. Now I cant use my JB4 properly.
I can't read logs neither on PC nor via Bluetooth.
Where can I get an older version ? for JB4 without OBDII
Default 10-16-2018, 07:45 AM
You can't. You'll need to convert it to new OBD style. You can find it here:
http://www.burgertuning.com/JB4_upgrades.html
It will be labeled as :
OBDII CABLE WITH JB4 SIDE CONNECTOR FOR RETROFIT
Default 10-16-2018, 07:47 AM
Can you email me, it will be easier to help you on this.
Payam@burgertuning.com
Default 10-16-2018, 07:50 AM
Thank you for the prompt reply.
However, I am Located in Russia. Delivery would take around a month.
Is there any other way of reconnection of existing wires for my JB4 to work?
notebookboy's Avatar
notebookboy notebookboy is offline
Car: 2013 Z4 20i
Default 10-27-2018, 07:48 PM
Hello BMS Team,
Just upgraded to N20_JB4_X1_Z4_2.hex on my Z4 E89 2.0T. And noticed that gauge sweep was disable. Checked for the other threads that it was move to steering menu 5/8 or 6/8. However, the max number on rpm is 7 on Z4. Any idea on how to enable the gauge sweep please?
Default 11-04-2018, 07:02 PM
It has it's own wheel control guide, should be in the current install manual for the N20 towards the bottom.
528n20 528n20 is offline
Car: 2015 528i
Default 11-05-2018, 11:40 PM
Originally Posted by bhom920
Just happened again. Here is a video of what it does https://youtu.be/6V0_9phU2Ps It almost seems like it wants to go into menu system and is showing that its on menu 0, Map 1. Is there a way to disable this menu option if it doesn't work with the x3?
Any update from Terry? Same happened to me again this Monday
Furbz Furbz is offline
Car: Bmw 320i F30
Default 11-09-2018, 01:40 AM
Just a thank you.
5 years with my 520i and JB4 +-65000km
pulled the chip out for each service.
map 5 always.
BMW service plan on the car has now run out. and so far in that time nothing has gone wrong.
Thanks Burger tuning for the great product
Default 11-09-2018, 10:57 AM
Originally Posted by Furbz
Just a thank you.
map 5 always.
This is awesome. Thank you for your continued support!
Car: 2013 Z4 20i
Default 12-29-2018, 03:10 AM
Hello Terry and Payam,
Is there anyway to modify the AFR for Z4 N20 firmware? I heard that MAP6 AFR setting doesn't work for E chasis N20.
Appreciated for your information. Thanks and wish you all a very happy new year!
Car: 2013 Z4 20i
Default 01-02-2019, 07:53 PM
Thanks Terry. Yes, I found it in the bottom of the latest N20 install manual.
It works great!
Car: 2013 Z4 20i
Default 01-02-2019, 07:55 PM
It's in the latest install manual for the N20 towards the bottom.
Originally Posted by Ripley
Hi Terry, there is something like this for N20 X1 & Z4?
http://www.n54tech.com/flash_files/jb4_wheel_1.jpg
Car: 2013 Z4 20i
Default 01-03-2019, 07:30 AM
Hi Terry,
Is there anyway to overwrite the hard limit of +10psi of JB4?
Does bit3 work with the latest Z4/X1 firmware?
bit3 - Raise "boost over stock" cap from 10psi to 20psi.
My car is E89 Z4 20i with N20B20A PWG. It's saying Map1 20 psi,Map2 22 psi and Map5 is Not used from the latest Z4/X1 N20 Wheel Control Guide.
Shall I use Map1 in this case? Would it reach 20 psi or it would be around 18-19psi as you mentioned JB4 has a hard limit of +10psi on any map.
Your input is highly appreciated. Thanks!
On the 320i factory boost is around 8-9psi, and the JB4 has a hard limit of +10psi on any map, absolute, or additive. So you would use map 1 and its 20psi target to get up to 17-18psi. You can use map 7 to do the same thing on a 320i. It will never hit the 23psi map 7 target as you'll get to +10psi over stock long before you do. Just like why you never hit the old map 1 20psi target.
Mak_5 Mak_5 is offline
Car: 2013 328i Sport
Default 01-05-2019, 12:30 PM
Hey im new to this thread and was wondering if anyone could help me. I’ve recently installed the jb4 on my 2013 328i sport N20. To my knowledge everything is stock with the exception of the M suspension. So no aftermarket charge pipe or ******** etc. Is it recommended that i stay on map 1 and/or is it safe to move up to map 2? I use 93 octane gas. Ive read most pages on this thread and couldnt really find a diffinitive answer. If i do need to make upgrades which one is most important to safely run map 2(charege pipe vs ********)? If im in the wrong thread my apologies. Any help is very much appreciated!
Brant Yu Brant Yu is offline
Car: F31
Default 01-07-2019, 01:05 AM
Originally Posted by Mak_5
Hey im new to this thread and was wondering if anyone could help me. Iíve recently installed the jb4 on my 2013 328i sport N20. To my knowledge everything is stock with the exception of the M suspension. So no aftermarket charge pipe or ******** etc. Is it recommended that i stay on map 1 and/or is it safe to move up to map 2? I use 93 octane gas. Ive read most pages on this thread and couldnt really find a diffinitive answer. If i do need to make upgrades which one is most important to safely run map 2(charege pipe vs ********)? If im in the wrong thread my apologies. Any help is very much appreciated!
Changing the aftermarket charger pipe to avoid the higher pressure causing the OE pipe from exploded / break is a must ; also highly recommend change the down pipe to decrease the exhaust temp and pressure to reduce the work load of engine as we are putting more boost to engine, the oil temp and exhaust temp are both higher than they were before installing the JB4.
Default 01-07-2019, 09:26 AM
Post a log in the support section so we can take a look.
Default 01-07-2019, 01:13 PM
Ok. Will do. Thanks for the replies!
wiliamsbarroso@gmail.com wiliamsbarroso@gmail.com is offline
Car: jetta GLI
Default 01-24-2019, 07:29 PM
aconteceu a mesma coisa comigo..
