inevitab1e's Avatar
inevitab1e inevitab1e is offline
Car: 2013 N55 135is
Default HPFP crashing to 6 WOT, LPFP time? - 09-30-2018, 07:58 AM
Issue started a couple months ago and has gradually gotten worse. WOT causes HPFP to crash immediately. Engine sputtering when it happens.
Replaced the fuel filter/pressure regulator and issue remains. Lower octane causes issue.
Any tips on what to try next? Notcied a lot of LPFP upgrades on the Fuel-it website. Don't want to do that route before I know it'll fix this issue.
From log looks like the HPFP crashes when the TRIMS signal increases from 25
2013 E82 135is N55 JB4-BEF FBO
Default 10-01-2018, 07:15 AM
Looks like you're stuck in some sort of open loop. Try setting open loop to 0 and see if that does anything. HPFP might be the culprit.
inevitab1e's Avatar
Car: 2013 N55 135is
Default 10-01-2018, 01:09 PM
Set FOL to 0? I've got Trebila doing a custom BEF. And the car was doing this before with the BMS BEF. Only started 1-2 months ago.
Here's a log where the HPFP crashed but didn't get the sputtering causing power loss. Slowly getting worse over the month.
inevitab1e's Avatar
Car: 2013 N55 135is
Default 10-05-2018, 12:27 PM
Replaced HPFP and issue remains. LPFP from Fuel-it on the way. I hope this isn't related to the JB4 in the end.
Default 10-05-2018, 12:56 PM
It looks much better than the previous log. Got anything recent with the new hpfp I can look at?
inevitab1e's Avatar
Car: 2013 N55 135is
Default 10-05-2018, 01:24 PM
That was a log from a month ago when the HPFP crashing was starting. I haven't been able to get a full log @WOT because of this current problem. Here's a log front today where I stepped on it and a couple seconds later I had to let off.
Could this have anything to do with a bad JB4 board? The TRIMS signal doesn't budge. This was FOL 70 again, fresh BEF, clear adaptations, etc.
inevitab1e's Avatar
Car: 2013 N55 135is
Default 10-10-2018, 01:35 PM
What could be causing the trims to stick at 25 and crash the HPFP? I've replaced the following and the issue remains.
-Fuel Filter/Pressure regulator
-HPFP
-LPFP stage 2
This doesn't seem to be related to either of the fuel pumps. What else can I try? FOL @ 0 didn't change anything. Would o2 sensors have anything to do with this?
I can't believe I've spent all this money and the issue remains. Look at how rich this log is at partial throttle just before WOT
inevitab1e's Avatar
Car: 2013 N55 135is
Default 10-15-2018, 03:10 PM
New O2 sensors installed (upstream/downstream). Post *** looked beatup. Reset all adaptations w/ MHD & JB4. Loaded BEF again. Haven't gone WOT yet to allow the car to learn, but I did notice the trims sticking at 25 through the JB4 app around 40% pedal (that wasn't encouraging as that was the problem before).
We'll see tomorrow how the car reacts to WOT.
Pic of pre/post O2 sensors
inevitab1e's Avatar
Car: 2013 N55 135is
Default 10-16-2018, 12:09 PM
Problem still persists after O2 sensors change. Could this be related to software/JB4 somehow? I reinstalled all the connectors for the JB4 today as well.
Replaced items so far (all new)
-HPFP
-Stage 2 LPFP
-Fuel Filter/pressure regulator
-O2 sensors
-Plugs have 4k
-Coils have 20k
What else could be the issue here causing the HPFP to crash at WOT? Trims sticking in the beginning of WOT? JB4 ignoring boost targets on Map 6 (+3psi above targets)? Can you send me a new board to test?
1st Log = 3rd WOT (few seconds in, sputtering, let off, WOT again, sputtering)
2nd Log = Idling, normal driving 1st, 2nd, 3rd. Car running really rich, even hitting 12's for AFR's under medium throttle.
EDIT: Looking back through my logs, this TRIMS issue started after I got my DME unlocked and first loaded up a BEF (6/29/18). HPFP was fine back then, but gradually got worse. Trims still stick to this day.
