(#1101)
D-C D-C is offline
Car: Stinger
Default 12-02-2018, 12:12 PM
Hi Terry
As discussed on the stinger forum under Burger Tuning JB4 for Kia Stinger, my car barely spins wheels on launch and the consensus was something seems to be wrong with it so I have my concerns, the car doesn't even kick sideways. I took it for a run this morning in cool early morning conditions and logged with the following attachments. The car is running Map 5 with at least E30 and topped up with 98 fuel. Fuel wires are also installed. The only other thing installed is Eibach springs
Please look at the log files attached.
1st is take off with launch control
2nd take off without launch control
3rd is a 3rd to 4th gear pull
Default 12-02-2018, 04:33 PM
Originally Posted by D-C
Hi Terry
Logs seem fine to me, maybe those springs are helping with traction? Are you shifting manually or letting it shift? Get a dragy and do some 1/4 mile and 0-60 runs to see if it's putting down the power!
D-C D-C is offline
Car: Stinger
Default 12-02-2018, 04:57 PM
Thanks Terry
I was letting the it shift itself ? should I be changing the gears manually ?
Have I activated the boost by gear function ?
I want to get a dragy but I was waiting for you to add the IAT remapping wire to your store as shipping is expensive to Australia.
Default 12-02-2018, 05:01 PM
No I was just asking the question.
If you have warmer weather that might also be boosting your traction. It's cold across the USA right now.
Sboylan Sboylan is offline
Car: Kia stinger gt1
Default BMS Intake - 12-03-2018, 10:41 AM
Any idea when the BMS intake might be available?
Default 12-03-2018, 10:43 AM
Any day or moment now, lol. Waiting for the first production batch to be dropped off from powder coating.
D-C D-C is offline
Car: Stinger
Default 12-03-2018, 10:59 AM
Thanks Terry
Do you think you will be doing anything with the IAT remapping wire or adding to your shop anytime soon ?
Default 12-03-2018, 11:43 AM
Thanks Terry
The IAT spoofing isn't something the average user is going to need, I've been using it play with timing values on aggressive WMI maps. It's basically the same as the fuel wire with a small resistor in it, and a posi-tap, going between the JB4 connector and one of the wires in the JB4 MAP connector harness. So if you want it one easy way to get it is to order an extra fuel wire kit.
Default 12-03-2018, 03:05 PM
How much $ do you think?
brancky3 brancky3 is offline
Car: '18 Stinger GT2
Default 12-03-2018, 03:19 PM
Map 2 with new firmware and fuel bias settings. E85 sensor is showing 17 but it's probably higher in real life (my car doesn't idle much)
Default 12-03-2018, 03:40 PM
It will be a good value, but haven't set final price yet. Will this week.
Default 12-03-2018, 03:41 PM
Looks normal to me
Default 12-03-2018, 04:08 PM
Looks normal to me
Map 3 log coming tomorrow! The top end looks a little leaner, is that what the new fuel bias numbers aim for?
Smile 12-03-2018, 04:08 PM
Cool - reserve one for me
D-C D-C is offline
Car: Stinger
Default 12-03-2018, 06:26 PM
Will do Thanks Terry !!
Blueberry96's Avatar
Blueberry96 Blueberry96 is offline
Car: Kia Stinger Gt1
Default 12-03-2018, 07:58 PM
Alrighty, so just for knowing, how are you hitting 12.0 on your stinger? Its very impressive for sure, I guess I am just lost because I have all these modifications in the car and so far the best I got was 12.6 GRANTED my launch control is permanently disabled because of the d-pipe CEL I just want to understand. The youtube video said you're at 460 whp? Is it because of weather? Granted I am in Florida its hot as hell here, should I expect that I am at more horsepower?
I have intakes, primary and secondary d-***** muffler delete, running map 2 on 93 octane, Velossa tech inlet intakes, lowered, im also on 275/35/19 tires, pedal tuner, air fuel wires with your settings... what's different?
hungtran505 hungtran505 is offline
Car: Kia Stinger
Default 12-03-2018, 08:14 PM
What is the new fuel bias for the current firmware?
matt77 matt77 is offline
Car: Kia Stinger GT
Default 12-04-2018, 05:51 AM
Hi Terry,
Can you please look at this log and see if everything is ok? Map 2 with fuel wires, custom catback and secondary d0wnp1pes. Running Australian 98 RON. I will give Map 3 a go if you think everything looks good.
Matt
przemek.k przemek.k is offline
Car: Stinger
Default 12-04-2018, 08:42 AM
Hi
For the new soft 6 T4 shall I use the fuel wire settings posted on the first page or are there new ones?
Default 12-04-2018, 08:55 AM
Originally Posted by przemek.k
Hi
For pump gas the orignal ones, for those regularly running E85 the revised ones. But it's a minor difference really.
Default 12-04-2018, 08:56 AM
Originally Posted by matt77
Hi Terry,
Matt
Looks fine to me!
Car: Kia Stinger
Default 12-04-2018, 09:06 AM
Is the new fuel bias on the first post? I do not see it.
Default 12-04-2018, 09:20 AM
The (optional) revised fuel settings are in the first post.
Default 12-06-2018, 12:38 PM
How do you thing your intake will compare in price and function to the injen? The numbers you are showing with the bms intake are stunning
Default 12-06-2018, 04:26 PM
It's going to be less than Injen.
