(#201)
Car: Infiniti Q50 RS400
Default 07-12-2019, 04:58 PM
I don’t know if this is allowed, just wanted to share. Where is everyone buying their 50/50 juice? My first 4 gals I bought from Amazon for $41. Just bought a second set from sportcompactwarehouse.com for $40 shipped.
jrobohm's Avatar
jrobohm jrobohm is offline
Default 07-12-2019, 05:48 PM
I’m still on my initial Amazon 4 pack. I’ll take a look at these guys next order. I also picked up a gal of M1 to add to the Boost Juice. Honestly I cannot feel a bit of difference when I added 1/2gal to my 3/4 full 2gal tank.
I’m off to Jotech next Friday afternoon for another dyno run. Hopefully I am dialed in now that I’m running pump 93 + WMI. My AFR numbers (thanks to the fuel wires I’m sure) are typically in the 12.4-12.5 range at WOT. Fingers crossed for a hot NTX dyno run close to Terry’s 450whp.
BMS WMI
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI
  • AMS HE
  • AMS LDP
Q50Philly's Avatar
Q50Philly Q50Philly is offline
Car: 2018 Infiniti Q50 Red Sport
Default First log with WMI Map 8 - no tweaks - 07-13-2019, 06:24 AM
Hi Folks - see attached for my first log with WMI Map 8 - no tweaks. Any advice? Thanks in advance!!
2018 Q50 Red Sport AWD
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
AMS Red Alpha Cold Air Intakes
Megan Racing LDP
Tanabe Y-Pipe
Mishimoto Oil Catch Can
Default 07-13-2019, 09:46 AM
Do more full throttle!
Q50Philly's Avatar
Default 07-13-2019, 10:11 AM
Will do, thanks!
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
Megan Racing LDP
Tanabe Y-Pipe
Q50Philly's Avatar
Default 07-13-2019, 12:53 PM
Ok Terry. How’s this (attached)?
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
Megan Racing LDP
Tanabe Y-Pipe
Default 07-13-2019, 02:17 PM
Better, looks good to me!
jrobohm's Avatar
Default 07-13-2019, 03:45 PM
I have to ask - WGDC and LPFP / HPFP logging seems like we are looking at some new numbers which will be important in the coming weeks !?!
  • BMS CAI w/ Inlets
  • BMS WMI
  • AMS HE
  • AMS LDP
Car: q50
Default 07-15-2019, 06:28 AM
I would settle for some additional PIDS
Default 07-15-2019, 10:27 AM
I'd like to get WGDC on there also. Easier said than done. There are only so many standard logging PIDs. The flash tuners are able to add a few more through the flashing process. We'll see if we can open things up once we have good back end flash tools available.
Car: q50
Default 07-16-2019, 05:32 AM
Got my WMI and JB4 back on....its hilarious how much faster the car rev's compared to without this stuff.
Default 07-16-2019, 09:12 AM
Right? It's like a totally different animal.
Car: q50
Default 07-16-2019, 09:47 AM
Yeah its brutally hot here right now and the car makes more power and yet the IAT's are probably cooler cause of the WMI.
Q50Philly's Avatar
Default 07-16-2019, 05:55 PM
Loving WMI and wondering if there is any reason to tweak WMI settings? Getting a Dyno end of next week!
Terry/Payam - Here in PA, I run 93 and Map 8. Is it safe to add 7 octane using VP Racing’s “MADDITIVE”? If so, any changes needed or will WMI make adjustments dynamically?
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
Megan Racing LDP
Tanabe Y-Pipe
Default 07-17-2019, 09:27 AM
It's basically the octane, the fuel volume, and lowering IAT all in one package that is helping the car move like it does!
I haven't heard of the Madditive, but I guess it could help bring the in tank octane up. The methanol should do most of that though. No changes needed.
Q50Philly's Avatar
Default 07-17-2019, 04:24 PM
Thanks Payam!
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
Megan Racing LDP
Tanabe Y-Pipe
jrobohm's Avatar
Default Latest Dyno Run - 07-19-2019, 07:58 PM
I took my 2017 Q50 Premium to Jotech today for another baseline dyno. Since my last posting I have added the BMS WMI kit to my car. The 406 / 425 run was from June 14th 2019 here in NTX. Temps that day were in the low 90's with just under 50% humidity. I was running an E30 blend of fuel with my JB4 set to Map 7. AFR #'s with the BMS Fuel Wires averaged high 12's to low 13's - trims were maxed out due to the high E content and stock LPFP/HPFP.
The addition of the BMS WMI kit (BA=80) yielded today a nice bump to 423whp and 454 torque. Today's temps in NTX were high 90's and just over 50% humidity. I used Boost Juice and pump 93 octane fuel. AFR #'s with the BMS Fuel Wires averaged 12.3-12.6.
BMS WMI
  • BMS CAI w/ Inlets
  • BMS WMI
  • AMS HE
  • AMS LDP
Q50Philly's Avatar
Default Yesterday, 05:03 AM
Congratulations, a nice increase for sure! Will be interesting to see your next 1/4 mile results
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
Megan Racing LDP
Tanabe Y-Pipe
Car: q50
Default Yesterday, 05:19 AM
That's a nice bump given that you removed the E content. Any comparison I'm boost levels from map 7 to 8 with the BA of 80?
Default Yesterday, 10:18 AM
BMS WMI
5oh_mo 5oh_mo is offline
Car: Q50
Default Today, 06:40 AM
What would be the most cost effective way to install a WMI on a Q50?
17' Q50 RS
jrobohm's Avatar
Default Today, 08:32 AM
Is the question DIY vs Professional Install OR should I get a one gal tank vs 2 gal tank? I also presume you have a JB4 already ?
  • BMS CAI w/ Inlets
  • BMS WMI
  • AMS HE
  • AMS LDP
Cherk947
