(#1501)
GtiGyver GtiGyver is offline
Icon1 Metric Speedo Calibration issue - 02-24-2011, 08:34 AM
Here are pics of the various speedo needle positions:
maybe make it 1 = 10km/h, 2= 20km/h.....
kang159 kang159 is offline
Car: 2010 335i Coupe
Default 02-24-2011, 11:17 AM
Pre-boost vs. manifold boost.
Ahh. Thanks Terry. Learn something new everyday.
Bimmer Barney's Avatar
Bimmer Barney Bimmer Barney is offline
Car: 07 E90 335i
Default 02-24-2011, 12:14 PM
I did about 8 runs last night on the latest firmware version Map 5. I'm completely stock e90. Max pre-boost I saw was 14.2, but most pre-boost numbers were in the 12.5-13.5 range. This was 91 octane, about 50 degrees out.
What number am I looking at to see how much boost I was pushing? Is it pre-boost? ecu-boost?, or target boost?
Default 02-24-2011, 12:18 PM
Sustained preboost.
Car: 07 E90 335i
Default 02-24-2011, 12:41 PM
Cool! Thanks. Loving this Map5 auto-thing. In my case, appears and feels a bit more conservative than Map 1, but also "smarter" than Map 1. After some more "learning" sessions, I'd like to try some launches and see if there's any difference in traction with the adjusted boost of Map 5 vs. Map 1.
Dirty Dog's Avatar
Default 02-24-2011, 04:13 PM
That's exactly what my speedo reads also.
DeadEye's Avatar
DeadEye DeadEye is offline
Default 02-25-2011, 05:26 AM
Have you done a needle reset?
Dirty Dog's Avatar
Default 02-25-2011, 03:55 PM
Yeh, many times.
Dirty Dog's Avatar
Default 02-25-2011, 03:58 PM
I know this one has been covered before but gonna install my c@tless DP's on tuesday, do I just set the JB4 to auto clear codes? I know it's an all or nothing with deleting codes so with this feature enabled you'll have to monitor if there's any other codes thrown?
Default 02-25-2011, 06:16 PM
Found a bug in the 135i metric tables. One of you guys email me and I'll send you an update to test.
Dirty Dog's Avatar
Default 02-25-2011, 09:41 PM
Us metric guys should have been first priority seeing as our measurements are in the correct format.
Default 02-25-2011, 11:30 PM
Metric FTL! Firmware emailed!
Orlin's Avatar
Orlin Orlin is offline
Car: 08 135i
Default 02-26-2011, 12:24 AM
Do I need this? or should I just wait for the next update?
mikeyt13 mikeyt13 is offline
Default 02-26-2011, 08:43 AM
Still cant get firmware to update. I have connection but when I hit update it brings me to.a file folder. Any ideas?
E36graduate E36graduate is offline
Car: 335xi Sport
Default 02-26-2011, 08:47 AM
Your computer is asking you where the Hex file (firmware update) is........You have to download the firmware (hex file) to a file on your computer....somewhere so that you know where to find it. Then go back to doing what you are doing and open up the file you downloaded.
2013 335i M-Sport - 6MT - Not too many mods.....Yet !
Car: 335xi Sport
Default 02-26-2011, 08:52 AM
Correction:
1. Stop what you are currently doing.
2. Go to the internet, to the sticky on this forum and download the latest firmware update.
3. Save this hex file to your computer (take note of the location of this hex file)
4. Go to your JB4 program and run the update firmware.
5. Your program will ask where the file is.
6. IF you remember where you saved that hex file, click on the file and a few minutes later you should be all set. It takes about 2 minutes and you can see the status.
johno johno is offline
Default software questions - 02-26-2011, 11:37 AM
I installed the software but there is no link on my desktop nor any sign of it in the program menu. Do I have to click on the .exe file every time I want to use the jb software to update firmware?
rgpwr's Avatar
rgpwr rgpwr is offline
Car: 09.e92.335i
Default 02-26-2011, 11:46 AM
The installer puts the JB4 shortcut in a "Microsoft" folder in your start menu
[ 09.e92.335i.a52 / procede.v5 / ets.fmic / afe.intake / eibach.pro / miro.368 / dimisa.4 / cityvision.ae ]
Car: 335xi Sport
Default 02-26-2011, 11:48 AM
1. Use your search function and find out where you saved the software.
2. You should have a one-touch program launch key somewhere, otherwise you may need to setup the software again?
3. You don't need the JB software running to download firmware, however you need JB software running to upgrade the firmware into your JB installed in your car. Car can't be running, but must be ignition on (LIGHTS ON DASH).
4. You shouldn't have to run an execution file every time you want to run JB software. Just find the program file and the JB launch should be there.
Default 02-26-2011, 11:51 AM
Yes that is on my "to fix" list!
alpinedevil335's Avatar
alpinedevil335 alpinedevil335 is offline
Car: 09' 335i Sedan
Default 02-26-2011, 12:38 PM
While JB software is running, right click it on your taskbar and select "pin to taskbar". That will create a easy to find shortcut to the JB software.
Jnic335i's Avatar
Jnic335i Jnic335i is offline
Car: 08 E92 335i
Send a message via AIM to Jnic335i
Default 02-26-2011, 12:49 PM
That is what I did.
JB4 | BMS DCI | UR DP | H&R | LC Z2s
Default 02-26-2011, 01:25 PM
WHats the name of the actual file?
Car: 09' 335i Sedan
Default 02-26-2011, 01:44 PM
JB4.exe I believe ?
Default 02-26-2011, 02:17 PM
I follow the jb4 files and it just ends up in an empty one. Cant figure it out
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
