(#2501)
BMW335E93's Avatar
BMW335E93 BMW335E93 is offline
N54 enthusiast
Car: 2009 335 E93
Default 06-01-2011, 01:12 PM
Originally Posted by pbonsalb
If it is happening near redline, it is the shift light. The steering wheel control guide says it can be turned on or off, but I have not tried yet. I have the February update JB4 and get the shiftlights on my auto trans left in D.
I've been wondering if the exterior flashers light up as well when shift lights come on or if it's only the dash lights
2009 335 E93 - Cobb FSR Protune - Custom FSR 4" Exhaust
Default 06-01-2011, 01:33 PM
Interior only, lol!
2008e90 2008e90 is offline
Car: 08 e90 sedan
Default Futureused - 06-01-2011, 02:51 PM
Is there a central place that contains all the variables for FutureUseD parameter?
Default 06-01-2011, 02:51 PM
No, just the release notes.
NihonX NihonX is offline
Car: 1M
Default 06-01-2011, 02:57 PM
Can't wait for the max cool!!
I've been playing with the radiator fan at 100% by BT tool. I think I might replace the 600w fan with the 850w fan. Is this possible or do I need to have BMW program it also?
Elie335's Avatar
Elie335 Elie335 is offline
;o
Car: E92 335i/320i
Default 06-01-2011, 03:01 PM
where are you getting the 850w fan from please?
335iMspizzle 335iMspizzle is offline
Car: 335i M sport
Default 06-01-2011, 03:08 PM
4) Enabled methanol mapping additive and overflow failsafe for user definable map 6 as well as map 3.
Map 6 is a custom map as I understand ? I can have this as an aggressive map for the strip, with the race gas to get the most power out of it ? Thanks !
Car: 1M
Default 06-01-2011, 03:22 PM
They usually come with the Performance Power Kit but I wanna try ordering the M3 fan by itself from Tischer.
Default 06-01-2011, 04:03 PM
The most common use would be to setup the curve you want for say pump gas, and then use a smaller meth additive of say 20-30 to pump boost above that on meth. Just remember the lower the meth additive relative to total overall boost the less room the safety system has to work with.
GtiGyver GtiGyver is offline
Default 06-01-2011, 07:05 PM
Hey Terry,
need any help to test metric scaling on any of the new gauge options?
M1588's Avatar
M1588 M1588 is offline
n54 addict
Car: 2008 335i
Default 06-01-2011, 10:51 PM
What about economy map 4? Any chances this will work soon?
2008 335i JB4, DCI, AA ***, Coolingmist meth kit with CM7
GSXR_MARKY's Avatar
GSXR_MARKY GSXR_MARKY is offline
Member
Default 06-02-2011, 01:57 AM
Yip could do with the economy map, it's $11.70 for a gallon of UK pump gas...
2009 135i - JB4 - DCI - Contemplating Meth - Cold Scotish Weather
Default 06-02-2011, 09:56 AM
Originally Posted by GtiGyver
Hey Terry,
See attached for the scaling. Not overly metric friendly but will work.
Having to sort out a couple more things and we'll get going on that. Not sure if it will make it in the next firmware release yet.
luv135i luv135i is offline
Default 06-02-2011, 10:26 AM
So is the alpha firmware out for testing or am I missing it in the thread somewhere?
Default 06-02-2011, 10:49 AM
No still working on a few things with it.
elsabor67's Avatar
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 06-02-2011, 12:20 PM
Originally Posted by just2sxy
where did u get that maxcool firmware?? i neeedddd !!
Sorry for the misunderstanding, I was referring to the previous post where terry was detailing the next releases that will be coming out.
My bad
timhatimay's Avatar
timhatimay timhatimay is offline
Default 06-02-2011, 02:54 PM
No, I always catch it out of the corner of my eye, but I've never been above 3-4k when it happens. Usually cruising in 5th or 6th. Its very strange! I haven't found any codes yet either to indicate a problem, maybe my car is just possessed.
Tim
Default 06-02-2011, 03:10 PM
Made another change a few of you might like:
17) Changed "stealth gauge" mode to trigger over 50% throttle and added 10 second delay when going under 50% throttle before gauges return to stock operation.
GSXR_MARKY's Avatar
Member
Default 06-02-2011, 04:08 PM
Excelent, do you have a release date yet?
Blue Streak Blue Streak is offline
JB since 2007
Car: 2007 335i
Default 06-02-2011, 04:17 PM
YES! I was just going to ask about that! This is a big improvement for the stealth gauge. Thank you!
Default 06-02-2011, 04:42 PM
No, we're smart enough to never release dates.
Default 06-02-2011, 05:33 PM
Tim
I'd suspect the V2 gauge which also intercepts the CAN wires.
prelude2perfect's Avatar
Car: '07 335i
Default 06-02-2011, 10:28 PM
The people speak and Terry answers, if only politics were this smooth. Great improvement T!
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 06-03-2011, 07:11 AM
Does the JB4 raise boost in the heat, it seems as im maxing Map2 out boost wise now that the weather is above 80*F always
2014 F10 535i N55 PWG
