(pardon the new account, don't have the email for my old lurker account)
Howdy y'all,
I'm currently running a 330i on Map 2 with a DP and ~94 octane fuel (AKI). I'm noticing some weird behaviour (from throttle closures?) when running the car in cooler (sub 15C) weather. The behaviour doesn't seem to occur in Map 3 where boost is a lot flatter (far less throttle dips) but trim steps up fairly fast.
I have a log of the Map 2 run. I apologise that its a little junk as I ran it spontaneously after noting the boost swings/throttle closures.
Any help would be appreciated as this foreign territory for me coming from NA BMWs and turbo Audis.
Something isn't right there. Maybe an install issue? Upload pictures of your install so we can check them out.
All of the issues went away for the most part by lowering gain to 10 and/or just running Map 3. But, it is still a little funky.
I'll try to get some photos in the morning. One suspected question is my EWG connection (A friend had the connector/wire melt) as I had an issue shortly after going to V20 where the waste gate was locked open (and the car built 0/negative boost) until I popped the car into neutral and back into drive. After that, the car behaved completely normally.
Yeah, post pics....you shouldn't have to drop PID gain to 10 and it still seems a bit wonky. You could also disconnect the EWG connector completely to test.
Sorry for taking a few days, work took most of my time so I elected to drive my other car.
Photos aren't great (May upload them separately and I have a few more) as I took them after work but this is the current state of things. I can take more with things unplugged to show the state of the pins/connectors if you need. I tried to keep the JB4 away from the OEM wiring as it wasn't terribly well done when it was replaced.
Also attached is a Map 0/2 log. The first run is 0, then I drove the car around to relearn Map 2 before doing 2 runs.
It's getting better as it was REALLY bad. Throttle closure isn't great, but may need some more time for adaptions?
Yeah, I’m not too familiar with JB4 but from a general tuning/automotive standpoint things looked and felt rough. I’m going to keep things weak for now because I’m a little worried about the car. I was quite surprised by how lax my DME is and I can’t imagine it being a replacement DME would make much difference.
Update after time for adaptation + ~10 more runs -
12-24-2021, 11:31 PM
I’ve let it settle in for a while on Map 1, this is about as good as it’s really getting. I’ve attached another log.
Some info:
- Car is running E20
- Oil consumption seems to have spiked no matter the map, safety map included. No smoke or smell though.
- No idle issues or surging.
Update and quite a severe issue. -
01-23-2022, 03:32 AM
Sorry for being gone a hot minute!
Here is a Map 1 log that came out well. The log was done with ~E24 mix as even Map 1 was a no go with anything less than E20. The most success I had was with a Map 6 based on my Map 2 which built timing far more linearly.
However, last night everything came to a head where the car started knocking hard and then the JB4 cut out about 5 minutes after I swapped to Map 8 to try to minimise any further timing drops. Unfortunately, Map 8 showed basically the same pattern of timing drops after changing up a gear; even at partial throttle. I've attached the auto logging from after the first incident. This was also the first time the car threw knock codes. I noticed in the Map 6 log that the boost targets vs what I set didn't seem quite right when compared with any of my previous driving.
At first I thought it was just the mobile connector dropping out and it was unrelated. This was because after the connection dropped and I had to stop the car it was now stuck on 'awaiting handshake' whenever I tried to reconnect. However, I can't get anything from the JB4 wired either. For now I've removed the JB4 and the car stopped having timing drops immediately.
Logs look good, definitely making more power in map 1.
Cool, glad at least something looks good right now. I’m still wary of the misfires though. It looks to coincide with the trim spikes after shifting gear. I have a few other logs from the Map 6 and 8 after as well.
I’ve managed to get the JB4 going as a test on Map 8. Judging by how I had to try a few times (moving the wiring loom around at the JB4 end after disconnecting the 2 batteries) it looks like the JB4 probably lost power while I was driving.
