Was able to get a 2020 facelift C43 model in for a little test and tune fun!
Best run 100% stock on 91 octane was 340whp/350wtq.
JB4 (no BCM) on 91 octane testing was 380whp/412whp on map2. Really solid gains under the curve overall.
Next we decided to mix in 4 gallons of E85 for ~E30 and installed a BCM. Power jumped up to 400whp/488whp using (new) map5.
Finally we got to what we really wanted to test. The BMS intake using our new V3 heat shields (in development now), and got power up to 419whp/496wtq. I attached a log of that run for reference. Boost is up there at 21psi peak tapering to 15psi but nothing too crazy. Probably more in it next go around.
Finally for kicks we disabled the BCM so we could see what the likely max facelift power is without it. Peak was 413whp/447wtq but you could see the massive torque reduction down low in the charts. The BCM does wonders for facelift cars running E30!
We were not able to test 91 octane + BCM but I don't expect it would do a ton. Maybe on 93 octane... Next time!
Have you guys gotten a check engine light for low fuel pressure. Had one twice in 2 weeks on stage 3. Hit the limiter a couple night ago and it popped on as well. Have you guys seen this before? I was reading another thread where someone hooked up a green wire?.
The car is a 2020 C43 convertible, BMS intake, JB4, BCM.
Would you expect the same power curve changes with the BCM on non-facelift?
Not quite as pronounced but should still see a nice torque boost with it.
This will also work for 2022 GLC43 right? Should be the same numbers?
Yes!
