(#6201)
Magus25 Magus25 is offline
Car: 2016 Infiniti Q50 Premium 3.0T
Default 12-21-2021, 03:33 PM
Originally Posted by Alpha50
Yeah, you are pulling timing below 5 all the way down to 3.0. Check your E mix make sure your checking it at the pump. I would try map 5 which is BMS’s 7 psi map. It should work better. What are your settings for map 6? I ran 9 psi over on map 6 on E30. Well with in the stillen report I might add and made 430whp.
I'll stay on map 5 i guess until i get a better map or e30 mix.
As for the map i got it from a guy in youtube. i'll post the picture of what i got.
Alpha50's Avatar
Alpha50 Alpha50 is offline
Car: 2017 AWD Q50
Default 12-21-2021, 06:06 PM
That’s not really what I would call a good map. In my opinion too much variation in boost and is most likely the reason for the timing being pulled. I’ll post a pic of the map I used on max boost E30 only. You can use it as a template for your 7.5 psi over map 6. Note: The map posted takes several mods to run including lower downs, intakes, HX,E30 and more.
joshhooper joshhooper is offline
Car: Q60
Default 12-29-2021, 04:08 PM
The car has been acting weird so I logged a Map 1 pull. Does everything look good or is there an issue with AFR or timing?
Q60 with BMS HE, LDP, Exhaust, JB4
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 12-30-2021, 10:43 AM
This log looks very normal/healthy to me. What do you mean by "acting weird"?
Default 12-30-2021, 11:58 AM
@joshhooper
All of your user adjustment settings have been zero'd out. You'll need to put all of them back to the default values.
Infiniti Q50 3.0t VR30DDTT Red Sport and Silver Sport BMS Stage1 JB4 - N54Tech.com - International Turbo Racing Discussion
Car: Q60
Default 12-30-2021, 09:43 PM
Thank you! Car was throwing crankshaft timing codes (p0011 and p0021) and going into limp mode randomly. Wasn't every drive so I knew it was an electrical issue. The battery was bad and once replaced, the car went back to normal ever since. Just wanted to make sure there was nothing wrong with timing in the log.
Car: Q60
Default 12-30-2021, 09:44 PM
@joshhooper
Thanks, will do! Weird as I've never touched the user adjustment settings...
Q50_ds Q50_ds is offline
Car: 2016 Q50 3.0t premium
Default 2016 Q50 3.0t new JB4 owner (Non RedSport - 12-31-2021, 02:20 PM
Hey guys this is my first time posting here so hopefully Im doing everything right. I have a 2016 3.0t and recently got the JB4. Was able to get my first data log in today. Not sure if I did it correctly to im fully open to recommendations and suggestions. I will attach the CSV file. Did a 3rd gear pull on map 2.
SilentQ SilentQ is offline
Car: 2018 Q50S
Default 12-31-2021, 03:22 PM
Your log for a first timer was not all that bad. Started low in the RPMS and road it all the way out. Try getting into 4th and logging a bit of that. Be careful though if on the streets wait till your comfortable as you can really get going in 4th.
Try map 2 and log it. Map 1 log looks fine.
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 12-31-2021, 06:22 PM
Ditto Silent Q...looks like your good to move up...but looks like you switched to Map 2 right before the pull. I would post a map 3 and map 4 to see where you are at...just put it back to 2 until you get an all clear!
vneck323 vneck323 is offline
Car: q60 red sport
Default q60 red sport data logs - 01-04-2022, 11:29 PM
hey how's it going everyone. can I get someone's input on my data logs for my q60RS400 please? recently put jb4. only have 91 octane (California), got LD, CBE, and intakes. no heat exchanger yet. waiting for it to arrive. I did 3 different logs with map1,map2, and map3. does it look good? have not installed fuel wires. will be doing that soon. thank you.
Default 01-05-2022, 12:01 PM
Looks like you had some traction issues on map 3 but once you got going it looked normal. Definitely get the fuel wires as you are running pretty rich.
Car: q60 red sport
Default 01-06-2022, 12:23 PM
Thanks for your input. Also, can I run map 6 and adjust the boost? Or I can only run map1-3?
Default 01-07-2022, 12:02 PM
Anyone can run map 6 and put in whatever boost targets they choose...I'd just caution you on doing so unless you're familiar with tuning.
FloridaQ FloridaQ is offline
Car: 2018 Q50
Default New to JB4 - First Map - 01-23-2022, 08:29 PM
Hello Guys,
Hoping I am in the right area for this.
New to the JB4 and the Q50 scene. Posted map below is my 3rd gear run on map 3. 2018 Luxe-AWD-MBRP CBE-AMS LDP-BMS Hx-BMS INTAKES-OCC-93 Fuel.
Car: 2018 Q50S
Default 01-24-2022, 07:28 AM
Originally Posted by FloridaQ
Hello Guys,
Upload your logs in CVV format so it’s easier to read! Thanks!
Car: 2018 Q50
Default 01-25-2022, 05:07 PM
Gotcha! Appreciate the heads up and the feedback!
Attached CSV file below...
Car: 2018 Q50S
Default 01-26-2022, 08:20 PM
Looks good to me, can wait to see if some others give there feedback as well though
Default Fuel trim drop - 01-31-2022, 12:47 AM
Why is my fuel trip dropping after 4k rpm on wot?
Silversport22 Silversport22 is offline
Car: Q50
Default 02-18-2022, 12:33 PM
Linear pedal mapping option - does anyone know the difference between this function on and off. For example at 10%, 20%…….100% of pedal input what is the boost called for with it on vs off?
Default 02-18-2022, 04:45 PM
The linear mapping just makes the JB4 boost target more heavily weighed by pedal input.
MohammedS MohammedS is offline
Car: Infiniti Q50
Default Log and Rattle - 03-04-2022, 12:55 PM
Hello BMS team and fans,
This is my first participation on this forum as I have been using JB4 with conservative settings and exploring the results over the past two months.
I own a stock Q50 Luxe with 30k miles with JB4 without fuel wires installed, and I'm using map 6 with a maximum target of 4.5 psi with Middle East 95 RON fuel (equivalent to ~91 octane I think).
I think I'm already limited by my fuel so I haven't gone higher (you may still advice if I could go higher). However, the other day I noticed that my timing hitting 0 on the same fuel tank that it wasn't. Attached is two logs with the same JB4 settings and same fuel tank with 7 days in between, and I would appreciate it of you can take a look and advice. And I'm sorry for the long log but that's what I have showing the issue.
Another issue I want to bring up is that I hear a rattling noise when I coast at idle and a strong rattle noise when shutting down the engine, everytime since I installed JB4. I disconnected JB4 and the noises disappeared, so it seems to be JB4 related. Any thoughs?
Car: 2018 Q50S
Default 03-04-2022, 05:31 PM
Looks to be fine. You aren’t going 100% full throttle from the looks of it though. Try and put the pedal All the way to the floor. In your first log you stopped at like 70%. Also timing will drop to 0 when you shift if that’s what your seeing
Car: Infiniti Q50
Default 03-05-2022, 04:12 AM
Attached is a cleaner log with the same map 6 settings. Can you advice if I can run higher boost or I'm already hitting the limit for the fuel used?
Also, I recorded the rattle at shut down and you can see I'm the attachments. At 3.5 sec I pressed Engine Stop, and the rattle is shortly after.
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 03-05-2022, 08:51 AM
Log looks clean and healthy to me. I would stick with the stock maps until you get more experience with JB4/tuning and have specific goals for a customer map 6. From where you are, I would log a map 3 and see how it looks. Post back here and we will see how it looks.
