N5(4x4) N5(4x4) is offline
Car: 2008 335xi
Default Car throws codes unless Jb4 Bluetooth is connected. - 01-07-2022, 04:40 PM
Car is a 2008 e92 335xi.
I have an issue where the car will throw codes 2CFB
and 2B09 every startup and the idle will surge and car is undriveable. If I connect to JB4 Bluetooth mobile before starting car, the car won’t throw codes, and runs perfectly fine. Any help would be appreciated.
Default 01-10-2022, 11:43 AM
What are the descriptions for the codes? That seems rather odd.
Car: 2008 335xi
Default 01-10-2022, 01:16 PM
The descriptions are as follows:
2CFB Throttle adaptation value
2D09 drosselklappe
It is very odd. I haven’t found any other examples of it happening online in hours of searching. There are however examples of these codes being thrown, and I’ve tried the suggested steps in those threads.
I replaced and coded new battery which it needed anyway. New intelligent battery sensor. Replaced voltage regulator. I have plugged in and unplugged the throttle body connector several times. Taken off the throttle body. Cleaned throttle body. Put a new gasket from charge pipe to throttle body. Reset adaptations. Codes still show up on every startup, unless I connect to jb4 before starting the car. Then it runs perfectly.
Car: 2008 335xi
Default 01-24-2022, 07:55 PM
So I bit the bullet and replaced the the throttle body itself. Started right up without having to link to jb4 Bluetooth. Seems to have fixed everything. Weird but I’ll take it! Hope this helps someone else. ��
Car: 2008 335xi
Default 01-24-2022, 10:15 PM
Well I spoke too soon. After the car sat for a couple hours it had surging idle and threw the throttle body codes again. So new throttle body didn’t fix it.
Car: Evo VIII
Default 01-25-2022, 11:41 AM
Please upload a log with the occurring problem. Thanks!
Car: 2008 335xi
Default 01-25-2022, 01:44 PM
Ok thanks. I logged when it was surging idle. And I logged after clearing codes, and connecting the jb4 Bluetooth. It combined it into one log I believe.
Default 01-25-2022, 03:45 PM
Not really sure what that issue is. Have you specifically reset throttle adaptions? That's not really something JB4 related but I'd also recommend updating your firmware and putting all the JB4 values back to the default settings.
Car: 2008 335xi
Default 01-26-2022, 03:32 PM
Thanks for the reply! I have reset the throttle adaptions manually several times. I just updated the firmware, although it was the firmware I was running before. To be certain I shouldn’t install the beta firmware? Also how do I put the jb4 values to default? Any link would be appreciated. I searched around but I’m not seeing any values other that’s the original post from 2010.
Default 01-31-2022, 02:43 PM
No problem running beta software but it doesn't sound like it will resolve your issue. This sounds like it may be more hardware related.
The default values can be found here...
E Series N54 JB4 - N54Tech.com - International Turbo Racing Discussion
