(#401)
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 07-29-2021, 01:00 PM
OK,
3 snips from your map5, If you're pulling 3 and more deg consistently you have issues. Here, you are...... Over 20 psi on 1 step plugs isn't going to last. That's why your Map2 looks the way it does now. The log isn't the worst but if you want the car to be happy, get those 2 steps in and send another log. The car WILL be faster do to increased timing and you will have a larger window for variances in octane. I've always agreed with Terry (who can't) when he says never tune for zero deviations, but at some point you have to support the boost with the right hardware.
Djfourmonie Djfourmonie is offline
Car: 2020 Kia Forte GT
Default 07-29-2021, 08:43 PM
Simple solution: Sunoco GT-260+ which is 13% E85 mixed with 100 octane unleaded.
Boostane made less power again in testing vs fuels with Ethanol mixed to boost octane because those fuels are oxygenated by the Ethanol.
The cooling effect lessens the need for colder plugs. Your timing problems would go away.
I run E20 every fill up. 1% observed loss in fuel economy. 450 miles to empty
2020 Kia Forte GT
6 Speed Manual
JB4+Bluetooth Connect
Burger Motorsports Water Methanol (45/55 mix)
Whiteline Springs
13.77@103
Map 7, E30+WMI, Hoosier Drag Radials
E85 Station Locator (US Only)
Stingerbob19 Stingerbob19 is offline
Car: Kia stinger
Default Top end log after EWG connectors - 07-30-2021, 07:38 AM
I was in Mexico long enough to get a couple upper end pulls. For you here who can read the matrix (logs), Is it better to have a longer log with a little before and after info? Or just capture the target foot mash to foot lift?
Thanks for all the help
Crashcade Crashcade is offline
Car: Ď22 Stinger GT2 AWD Scorpion
Default 07-30-2021, 08:21 AM
Iíll go back to adding a few gallons of E85 and see how it tracks. What sucks is road trips, itís hard to find E85.
Iím not a big fan of the Boostane **** at all. I figured Iíd get a couple cans and try. But I do have a couple thing going against me. One I am at 5100í elevation and ambient temps are close to 100*.
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 07-30-2021, 11:42 AM
Map 2 looks clean
St1nger Guy St1nger Guy is offline
Car: Stinger GT2 AWD
Default 08-08-2021, 05:43 PM
Add me to the list of owners that get a CEL with the EWG wires hooked up. I suspect my eprom is the old version because I got my JB4 back in 2018. I installed some waterproof wire connectors so I could dead head the EWG wires while leaving them in place and put the mating connector on the wires going to the JB4. Now I can have them installed or bypassed with ease. To clear the CEL I had to unplug the ODBII connector and both of the sensors on the engine, I left the fuel wires plugged in and it got rid of the CEL on next start up. I then plugged everything back in except the EWG wires and still no CEL, everything working as it should. Will get the new chip and report back.
Received the new chip, replaced and connected my EWG wires up again. No CEL, everything appears to be working great. I had to buy a cheap ODBII dongle off Amazon to delete the codes, the JB4 will not do it. Now I need to figure out what I'm supposed to do with the phone app to take full advantage of them. Anyone have any suggestions?
XnOVeNoM XnOVeNoM is offline
Car: kia stinger gt2 2020
Icon1 Log with EWG connectors. - 08-17-2021, 06:51 PM
P21_M2_R3_210817_1201.csv
I have intakes ,******* down *****, Hks plugs, jb4 with fuel wires and EWG connectors. Ando said my trims are maxing out wondering what I can change. I can do some other pulls and take logs of those if needed. Running 93 octane on map2. EWG connectors are at the settings that are the default.
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 08-17-2021, 08:22 PM
None of these pulls you were at WOT. Can't asses a log with 70% or less
Please do a 3rd 4th gear wot pull, pedal to the floor. Or a slow rolling start to about 100 or 4th gear
Default 08-23-2021, 11:19 AM
Inflation finally caught up to us on these and we had to raise the price to $100 per pair. Still well worth it.
djerickd djerickd is offline
Car: 2019 GTS
Default 08-25-2021, 11:06 AM
UGH I should have ordered them last week. Actually had a set LONG when you 1st released them but never installed them worried about the CEL issues, so I sold them to a local.
Car: 2019 GTS
Default 08-29-2021, 06:55 PM
Terry,
Can you check this log? I just got the EWG wired in.
Default 08-30-2021, 11:19 AM
Originally Posted by djerickd
Terry,
Looks pretty good to me.
Car: 2019 GTS
Default 08-30-2021, 07:53 PM
Thanks Steve, shoild I perhaps bump the FF up from 50 to 60 (or more), I thought saw earlier in the thread others were testing higher and higher values. Just wondering..
Default 08-31-2021, 09:44 AM
No need...boost is on target.
The_Cya_kia The_Cya_kia is offline
Car: 19' Stinger GT2 RWD
Default 08-31-2021, 09:57 AM
Hello,
I just got my JB4 and EWG wires installed yesterday. I went very slow, made sure the right pins are in the right place and everything is solidly connected as directed.
Before when WOT i could clearly hear my intakes making a loud sucking noise the entire time. Now a few seconds into WOT the sucking noise stops (I assume the gates are opening?). The car isn't making more than 4lbs of boost and threw a CEL with code 25A0.
If i go in the app and disable the EWG control everything runs fine and strong.
Today just to be sure I removed everything double checked it all seated well and was in the correct place. Issue persists.
The only odd thing i can think of is I do have connector 1 going to the drive's side and C2 going to the passenger's side, unlike the install example. (Noticed it after i locked in the pins.)
Current Mods:
Mishimoto FMIC
Mishimoto Catch can
JT Intakes
Velocitech Scoops
HKS Plugs
Break snip
Logs:
First log, first 1/2 EWG enabled 2nd 1/2 EWG disabled
Default 08-31-2021, 10:57 AM
Something is clearly wrong. Revert EWG connectors to factory first and do a log on map0 and map1 to confirm boost comes back up to normal.
Crazy-Stinger's Avatar
Crazy-Stinger Crazy-Stinger is offline
Car: 2019 stinger gt1
Default 12-29-2021, 06:35 AM
First order of business is those cars with modified exhaust that over boost, and of course large turbo cars who need more WGDC.
Is this only on exhaust or with the dowpipes?
khancerto's Avatar
khancerto khancerto is offline
Car: 2020 Hyundai Elantra Sport
Default 01-22-2022, 07:21 PM
Today I installed the EWG wires into my G70. Do I just start getting logs and posting them here for fine tuning?
2020 G70 3.3TT AWD
HKS M45IL Plugs
Default 01-22-2022, 09:04 PM
If you need help can email in logs. These days they are install and enjoy for the most part.
GreenGSX GreenGSX is offline
Car: 2018 Kia Stinger GT2 AWD
Default 03-15-2022, 09:45 AM
Just installed the EWG wires installed today. Did a few pulls on Map 2. I set the adjustments to what was recommended in the first post and so far everything is working fine. The butt dyno says it pulls harder in gears 1-3 but I'll try this out when I go to the track in a few days.
I've attached a log and it looks like I've got enough fuel but I'm getting some timing being pulled in ign4. Not sure if this is a fuel trim issue that the ECU needs a few more pulls to figure out or a quality of fuel issue.
Not sure how to read the two boost numbers to see if there needs to be any further adjustment to help the JB4 reach its target boost (14psi).
Mods-
450hp kit
EWG wires
MBRP *** back
93-pump gas (florida)
Map 2
Default 03-15-2022, 10:03 AM
Mods-
450hp kit
EWG wires
MBRP *** back
Map 2
Looks fine to me! It would be uncommon not to have any timing corrections on pump fuel.
DR.JJ DR.JJ is offline
Car: Infinity 2018 Q60 Luxe
Default 04-29-2022, 08:35 AM
What would be the difference between the fuel control lines and the EWG add ons? Do they work on different aspects of the tune, or do they kinda work along the same lines?
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 04-29-2022, 09:23 AM
Stinger 3.3L EWG Connectors - JB4tech.com - International Turbo Tuning Discussion
Fuel Wires
These add on wires attach to the JB4 harness and your vehicles sensors to give the JB4 the ability to directly change the air/fuel ratio. The factory tuning runs in the 10:1 range and leaning that out to 11.5:1 has proven to be worth significant power at higher engine speed. Note these are preinstalled on the JB4 harness now so only need to be attached to the o2 sensor signal wire to enable using the included posi-taps or optional harness adapters.
Default 04-29-2022, 06:33 PM
Fuel Wires
If I have only a JB4, kn filters, deleted muff, 93oct, is it best to do one over the over, or just do both fuel control lines and EWG, since its easy? Oh yea, another question: Front sway bar or both? I hate the roll.
Posjr408 Posjr408 is offline
Car: 2022 Kia stinger
Default 05-13-2022, 11:14 AM
I thinking I'm doing something wrong. I lowered my bias duty and ff. Now my overboost is even worse. Am I supposed to be adjusting both? Going to reset my values and try again.
Did 40 across rpm for bias duty and ff at 40.
