badls12000 badls12000 is offline
Car: 2009 335i
Default N54 Issues with JB4 + BEF - 02-26-2018, 05:00 PM
Hello,
Issues with back end Flush. Car does not run right.
Car is 2007 BMW 335i 6speed manual
This is the file I was told to use JB4_BB2_I8A0S_PUMP.BIN. *****edited****
Is this correct.
File ending in 2155 was with BEF.
Files ending with 2256 and 2300 were flashed back to stock.
Any help would greatly be appreciated.
Dave @ BMS's Avatar
Dave @ BMS Dave @ BMS is offline
Default 02-26-2018, 11:28 PM
Set settings to default.
Race bef is fine, assuming you are running enough e85?
Log map 2 first and post logs
Car: 2009 335i
Default 02-27-2018, 03:20 AM
Dave,
My apologies for not being clear. I use 91 octane and max of 30% e85 mixture. Will the race file support this fuel type?
On BEF does it matter what map I use?
When you say default settings, what is default settings?
Car: 2009 335i
Default 02-27-2018, 03:25 AM
******Correction******
file I used was JB4_BB2_I8A0S_PUMP.BIN
Haynpunch's Avatar
Car: 07 E90 335i
Default 02-27-2018, 09:14 AM
http://www.n54tech.com/forums/showthread.php?t=10605
Post #3 is where you'll find default settings
set default settings
log 3rd gear, traction off, 2k to redline
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Car: 2009 335i
Default 03-02-2018, 12:38 PM
Got it.
Will do some testing when weather dries out.
Will post logs soon.
Thanks for everyone's support.
Dave @ BMS's Avatar
Default 03-02-2018, 10:28 PM
Dave,
Around 30%- id suggest the PUMP BEF
