Jt0407 Jt0407 is offline
Car: Bmw
Default FS: Fuel-it Bronze TBI $520 shipped! - 07-21-2016, 07:27 AM
Has a little over 100 miles on it and mileage won't change, as the car sits normally. Upgrading to PI, so no use for it, anymore. This is for the Bronze TBI only. No upgraded fuel lines, ethanol sensor etc etc.
$520 shipped!
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 07-21-2016, 09:31 AM
I assume this is the bronze kit:
-Throttlebody spacer
-Fuel solenoid
-Adapter and fuel line to connect to the factory fuel line
-Hobb's switch to activate system under boost
-Wiring harness
-Bolts for the throttle body to install the spacer
Correct?
Car: Bmw
Default 07-21-2016, 09:43 AM
-Fuel solenoid
-Wiring harness
Correct?
Yes.
sd306 sd306 is offline
Car: 2011 e92 N55 335i Coupe M-Sport
Default 07-21-2016, 10:52 AM
15 psi hobbs? and has it been adjusted? I'll give you $375 shipped.
Car: Bmw
Default 07-21-2016, 10:59 AM
Plus $150
Car: Bmw
Default 07-23-2016, 03:13 AM
Ttt
Denobd Denobd is offline
Car: 535i
Default 07-29-2016, 05:19 AM
Where are you located?
vwetish's Avatar
Default 07-29-2016, 06:38 AM
Originally Posted by Jt0407
Ttt
Is the 4psi or 15psi Hobbs switch?
mkster08 mkster08 is offline
Car: 2008 335 AT
Default 07-29-2016, 09:03 PM
Why pi over TBI? I ask cus I'm interested
BusaR8 BusaR8 is offline
Car: 335, CLS, Busa
Default 07-30-2016, 02:05 AM
Glws
