robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default SMOKING ISSUE? DIY PCV FIX! - 08-23-2015, 03:14 PM
(THIS DIY IS INTENDED FOR UPGRADED TWINS OR SINGLE TURBOS)
I was having problems with my car smoking and a good friend of mine (Aubeast) shared a system that he had designed and had been working on for several months so I followed his suggestions and fabricated the necessary components to make it happen. This is the same line routing as he uses, same fittings but I did a few things differently due to having a top mounted turbo.
***A HUGE THANKS AND SHOUT OUT TO JASON (AUBEAST) FOR CONTINUING TO CONTRIBUTE TO THIS COMMUNITY!***
NOTE: Do NOT use any different size fittings or lines. What I specify is what is required and has been tested to work.
NOTE 2: I am NOT responsible for any damage done to you or your car when attempting this DIY. This is not a project for a novice. I suggest taking the manifold and fitting to a shop to be modified - I have the proper tools to be able to accomplish this at home by myself.
This PCV fix has totally eliminated all smoke at idle, wide-open throttle and cruising! This system pulls vacuum at idle and wide-open throttle. Use of an OCC between intake and AD fitting is HIGHLY suggested. I also suggest using an AD Engineering OCC or a modified BMS OCC, as I did. Link below for my modified BMS OCC DIY.
CUSTOM OCC LINK: http://www.n54tech.com/forums/showthread.php?t=28787
Also - as you'll see in my BMS OCC DIY - the head ports were tapped and plugged. It is absolutely essential for this system.
STEP 1 - FLAPPER VALVE ASSEMBLY:
(You can use rubber or -AN lines, I highly Suggest -AN. Below is a link to my DIY on -AN lines)
-AN LINE DIY: http://www.n54tech.com/forums/showthread.php?t=20780
STEP 2 - 2 RB VALVE & AD FITTING MODIFICATION:
STEP 3 - MANIFOLD DRILLING & TAPPING:
In this process, slow is key to prevent cracking of manifold!
STEP 4 - FILTER MODIFICATION / VACCUM SOURCE:
(I have a top-mount turbo so yours might be different)
STEP 5 - LINE ROUTING:
Use only -8 AN Line to manifold and AD fitting and -12 AN Line for vaccum source. If you're using rubber, use equivilent size.
Cynical Cynical is offline
Default 08-23-2015, 04:39 PM
Pretty sick Rob. Much simplier than tapping the head and more effective.
-carbone.
robc1976's Avatar
Car: 2007 335i
Default 08-23-2015, 04:40 PM
-carbone.
Head has to be tapped still though, keeps pressure off VC ect
Default 08-23-2015, 04:41 PM
Damn was hoping doing this circumvented that
robc1976's Avatar
Car: 2007 335i
Default 08-23-2015, 04:53 PM
Tapping the head is easy man! Its not bad
blisstik's Avatar
blisstik blisstik is offline
Car: 2007 E92 MOTIV 750
Default 08-23-2015, 04:59 PM
Hmmm, doesn't the flapper side have oil coming out of it as well? So oil eventually builds up and ends up on the intake?
Just wondering why didn't you keep the flapper delete valve from AD?
MOTIV750 / MHD+JB4 / ADV / SB REAR O2
robc1976's Avatar
Car: 2007 335i
Default 08-23-2015, 06:05 PM
its a 2 part system. Have to have flapper. The system without didn't pull vac at idle...only WOT. This system pulls vac at idle and WOT
blisstik's Avatar
Default 08-23-2015, 06:11 PM
Got it. Is there a hybrid PCV valve to what you did with RB+AD? I didn't get why that was necessary as well.
Stucks Stucks is offline
Default 08-23-2015, 06:25 PM
man that is a busy engine bay lol.
nice diy tho!
Current: 2008 e92 335i coupe.
robc1976's Avatar
Car: 2007 335i
Default 08-23-2015, 06:40 PM
The AD engineering fitting is used in conjuction with RB valve so you have a external vac and PCV
robc1976's Avatar
Car: 2007 335i
Default 08-23-2015, 06:41 PM
nice diy tho!
Lol! ! ,
AUbeast86's Avatar
AUbeast86 AUbeast86 is offline
Car: 2007 335i e92 Coupe
Default 08-23-2015, 07:45 PM
Great job on the DIY man! Well done!
Default 08-23-2015, 08:49 PM
This might be a better way to do the same thing without the need for two oil catch cans and a special adapter. Just make sure to have some sort of a restrictor on the intake manifold side. Maybe using a 1/4" fitting there for example, so it can't pull too much vacuum at idle.
robc1976's Avatar
Car: 2007 335i
Default 08-24-2015, 05:33 AM
Update:
A few people where worried about pressure going to the PCV valve so I will update DIY
Aubeast did say his original design did have a vibrant check valve between manifold and OCC with arrow pointed towards manifold. I will add this to the OCC DIY. That will keep the pressure away from the PCV valve some are so worried about.
robc1976's Avatar
Car: 2007 335i
Default 08-24-2015, 05:35 AM
I like the way the BMS OCC will have 2 in my setup lol!
N54 TuNeR's Avatar
N54 TuNeR N54 TuNeR is offline
Cool ///Member
Car: E90 SEDAN
Default 08-24-2015, 05:46 AM
The stock check valve doesn't close all the way,the flap does close but there's a port for blow by back into manifold.You think replacing that with a check valve that closes fully under load is better?
SOLD
2004 E46 ///M3 MODDED
PRESENT RiDE
2008 E90 SEDAN G5 iSO-FBO FSB-100%METH-DUAL NOZZLES,Fuel iT!Stage 2
AUbeast86's Avatar
Default 08-24-2015, 06:11 AM
Absolutely not. I've already experimented with that and it pulls an absolute vacuum on the crank case which makes all the seals in the engine howl. That hole is needed because the MAP sensor in the intake manifold is looking for a specific vacuum that is calibrated by that hole in the flapper valve.
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 08-24-2015, 08:04 AM
I'm really enjoying that AUbeast86 has been working on this and gets the entire picture. I believe he is the first I've seen in this community to be quite honest.
Terry's schematic right off has one large issue, under low loads there is no filtration to occur, meaning there is no filtered air displacement pull into the crankcase as it is "vacuumed". Second to that it appears under low load there would be full plenum vacuum, not a "controlled" vacuum, as there should be via the flapper valve. The high load scenario however would work, and is a direct replication of the OEM and this DIY.
Rob
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 08-24-2015, 08:24 AM
Thanks for clearing that up
SOLD
PRESENT RiDE
AUbeast86's Avatar
Default 08-25-2015, 05:33 AM
No problem.
Vertigo's Avatar
Vertigo Vertigo is offline
Car: AW 335i
Default 08-25-2015, 07:08 AM
Nice work Jason! Very clean and well thought out!
2008 335i stock
Nordic335IM3's Avatar
Nordic335IM3 Nordic335IM3 is offline
Car: BMW 335I N54
Default 08-25-2015, 08:19 AM
question:
could you weld a venturi plug in the exhaust and hook that up to the flapper plug??
AUbeast86's Avatar
Default 08-25-2015, 08:24 AM
Originally Posted by Nordic335IM3
question:
Only if you want to suck exhaust into your crank case under idle.
Car: BMW 335I N54
Thumbs up 08-25-2015, 08:38 AM
.. ah well...
Car: BMW 335I N54
Default 08-25-2015, 01:09 PM
so if it gets hooked up straight to the PCV outlet , without the oem flapper, what would then happen, any problems?..
(other then its not street legal)
better or worse than oem setup.. offcourse no oil sucked into intake which is good..
