Car: 2011 e92 N55 335i Coupe M-Sport
N55 Pure Stage 1 Log Check -
07-18-2016, 07:29 PM
Hello,
Please review these two logs
Car:
2011 335i coupe N55 w/ oil cooler, Automatic trans
Performance mods:
JB4 ISO 5.11 w/ FlexFuel Wires, Stage 2 LPFP, DP, BMW PE, CP, 5" FMIC, BMS Intake, Pure Turbo Stage 1, GFB DV, Pure Inlet, N20 TMAP, latest ppk flash, alpina b3 flash
Ambient Temp:
95 fahrenheit
Fuel at the time:
e55ish
Logs:
3rd gear pull from 2500-7000 in manual mode, dsc completely off, kick down NOT pressed.
My Notes:
PWM is high initially and runs very lean when initially going WOT. I want to order the TBI in preparation for Pure Stage 2 or run methanol only to lower IATS and prevent it from running lean (IATs get to 150 after a few hard runs in this weather.) I am no pro so I come here, thanks!
User adjustment settings pages:
http://i.imgur.com/53IhMh5.png
07-18-2016, 07:35 PM
I'd kick up duty bias below 4000rpm but otherwise seems solid to me. PWM being high at higher RPM is par for the source with a Stage1 N55 turbo. Fueling and timing seem fine here.
07-18-2016, 08:32 PM
Thank you! I will repost logs once I adjust them.
Question: The AFR bias settings are not used unless PI, correct? So, I can set those all to zero?
07-18-2016, 09:51 PM
That is correct...it won't matter what they are set to without PI.
07-19-2016, 12:18 PM
Thank you Steve.
Attached are two new logs. 3rd gear pulls. DB from 1500-3500rpm is set to 55. 4000-7000RPM is 50. The AFR looks lean to me at the lower rpms on a 3rd gear only, but okay after shifting to 4th looks okay. Is that normal when doing a one gear pull? Multigear pulls AFR is fine.
Also, once this is refined, do you think I can increase boost anywhere?
07-19-2016, 06:42 PM
You're not going to be able to get too much more out of this turbo. AFR's look pretty normal and trims are fine.
07-19-2016, 07:39 PM
Thank you Steve, should I adjust the DB anymore? FF and PWM seem to have different shapes in the higher RPM range.
07-20-2016, 11:32 AM
You can dial it in a little bit up top, I'd just make all the DB's 65, FF 100 and not decay the DB's up top like you currently have them.
07-21-2016, 01:02 AM
Steve, I adjusted all DB to 65 set the FF to 100 and it learned down. I adjusted the boost a little. Seems to be running stronger.
Logs attached, thank you!
07-21-2016, 05:56 AM
Looks pretty good. HPFP is just about maxed out so I wouldn't recommend any more E85 but looks like you have it pretty dialed in as is and turbo is about maxed out.
07-21-2016, 08:18 AM
I'm running about e55. Would taking it down to e40-45 be enough octane for the boost targets?
Also, any other fine tuning I should do?
Thank you!
07-22-2016, 06:05 AM
Only the logs will tell.  Given you do have a couple corrections, I suspect it may not be.
Turbo is close to maxed out so there isn't a lot left in it but you can increase your boost targets if you wish to completely max it out.
07-22-2016, 11:33 AM
Thanks for all your help Steve and Terry! Would there be a benefit to run TBI with Pure Stage 1 to increase the ethanol content to help with timing?
07-22-2016, 05:20 PM
Frankly, there isn't a lot left to be had.
07-24-2016, 05:51 PM
