Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 08-25-2015, 01:13 PM
Originally Posted by AUbeast86
Only if you want to suck exhaust into your crank case under idle.
+1.
Originally Posted by Nordic335IM3
so if it gets hooked up straight to the PCV outlet , without the oem flapper, what would then happen, any problems?..
(other then its not street legal)
better or worse than oem setup.. offcourse no oil sucked into intake which is good..
Yes. Problems. Do NOT omit the OEM Vent Hose Vent hose (flapper). The system does not need further revisions. Just follow the principles of this DIY and you'll be fine
boostaholic boostaholic is offline
Car: 2008 AW e92 335i
Default 09-01-2015, 05:39 AM
Wow these pictures say more than a 1000 words! Its crazy how somebody can explain something in such detail, like many times on this forum that for some reason I just cant understand or just doesn't make since to me. You did an incredible job not only explaining how the system "really" works but also having very detailed pictures of the install and how once seen and explained, makes PERFECT sense!! Awesome pics, great DIY to make it fairly easy IMHO...As long as your careful and take it slow, anybody can really do this if they have the proper tools needed as well as the correct knowledge of what your doing major props for this DIY!! Thanks guys!
E92 A/W JB4 G5 ISO w/WEDGE PERFORMANCE FLASH+FBO+RB's+LSD+60% E85/93 mix 508whp 531 ft lb torque 11.73 @121mph on street tires with a 2.1 60'!!! NO METH!
robc1976's Avatar
robc1976 robc1976 is offline
Default 09-01-2015, 06:43 AM
I appreciate that! Rob beck had fittings that will make this even easier.
Stalker
Car: 335I
Default 09-01-2015, 09:14 AM
Rob, that fitting I dropped off for you yesterday unfortunately needs revised. The revision is something you could easily do yourself by grinding off the end, but will not be production piece as is. Sorry about that!
And yes, here is part #1 of the fix- RB External PCV valve. Next is the vacuum/pressure reference adapter which hopefully we have tomorrow or Thursday. By late next week we should have about 5-10 kits production ready for those wanting to finally get rid of the valve cover/gasket reference.
Thanks,
Rob
BostonBeemah's Avatar
Car: AW 135i
Default 09-01-2015, 12:08 PM
Thanks,
Rob
Woo!! I'm hoping the second piece is of a different design than the AD fitting as mine has been leaking since day one even on a brand new valve cover. Something similar to what RobC did above with some sort of clamp would be ideal than just a lock fitting on the factory tab IMO. Will shoot you an email Thursday as promise.
RIP 2008 AW/BL 135i
Stalker
Car: 335I
Default 09-01-2015, 12:46 PM
This is actually the piece that threads into the valve cover. The 2nd piece interfaces as a plug and play vacuum reference on the Intake Plenum.
Stalker
Car: 335I
Default 09-01-2015, 10:34 PM
Here is the 2nd adapter…
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 09-06-2015, 06:46 AM
When's the full kit with pics going to be released rob?
Torsion Torsion is offline
Car: 335
Default 09-08-2015, 07:31 PM
So is there any issue with not tapping the head, using the AD eng fitting which supposably blocks those ports and then using the vibrant check valve to stop pressure from getting to the CC?
Stalker
Car: 335I
Default 09-08-2015, 08:06 PM
We are still undergoing testing in the hands of 1 ST user. His results are sporadic, and we are still collecting data. Releasing anything now would be premature to say the least.
Thanks,
Rob
icewall icewall is offline
Car: BMW 135i
Default 09-09-2015, 06:51 PM
I just finished doing this for my rb turbo setup. It was a royal pain removing the valve cover and everything around it. Much back pain later and my car seems to run great now!
so far no smoking and I actually like the fact that my head is tapped and plugged up.
I will also say that I don't think this was easy to do. I expected it to take long and be hard but I had no idea it would take so long and be bent over that much to tap the head. Even with all of that said, I feel it was worth the effort!
BeGooD69 BeGooD69 is offline
Default 09-14-2015, 12:59 PM
Rob, if u guys need a 2nd-3rd beta tester I about to do mine like rob but using AD occ too. Where could I get ur adapters?
sy2639 sy2639 is offline
Car: 2007 BMW 335i
Default 09-14-2015, 03:49 PM
Under what conditions did you have smoke?
What turbo setup are you running?
E92 - JB4 G5, BB Flash, RB Turbos, BMS Meth, BMS DP, BMS DCI, ACT Race Clutch
Car: BMW 135i
Default 09-14-2015, 08:02 PM
rb turbos.
It only smokes during cold start idle. doesnt matter if I have catalyst start mode or if that is disabled.
I noticed specifically with my car that it is directly related either to how much oil is in the engine OR the oil viscosity. (it smoked A LOT less when I added a quart of thinner oil (40wt motul xcess. when I got a quart low I added some 20 wt to see what would happen and it barely smoked anymore.))
PLF's Avatar
PLF PLF is offline
Default 09-14-2015, 08:13 PM
rb turbos.
Sounds like valve seals... These will smoke on a cold startup mainly after the car as been sitting for a while.
marconi118 marconi118 is offline
Default 09-15-2015, 07:53 AM
where is this fitting supposed to be fitted? on the throttle body?
E92 420 E92 420 is offline
Default 10-06-2015, 01:18 AM
Any updates on this
UK V8Bait Tuned
Built Motor
TD Turbo 335i
robc1976's Avatar
Default 10-06-2015, 10:13 AM
Originally Posted by E92 420
Any updates on this
Running perfectly, no smoke at all. I am running dual OCC also.
Default 10-06-2015, 10:44 AM
Nice! Any pics of your twin OCC set up? And what happened to the fittings rob at RB turbo made up for u were they one offs?
UK V8Bait Tuned
Built Motor
TD Turbo 335i
robc1976's Avatar
Default 10-06-2015, 04:07 PM
I will get them posted up!
Stalker
Car: 335I
Default 10-06-2015, 04:48 PM
I'm making a moderate size batch of these fittings and will begin offering an external pcv kit, soon.
Default 10-15-2015, 03:06 AM
Is there a rough ETA on when this will be offered?
UK V8Bait Tuned
Built Motor
TD Turbo 335i
_ink's Avatar
Car: 335i DCT
Default 10-15-2015, 03:43 AM
and a nice comprehensive DIY too..
Stalker
Car: 335I
Default 10-15-2015, 05:48 AM
The plan is to have a batch of these production worthy and ready for sale by Nov. 1st.
quing quing is offline
Car: bmw 335i
Default 11-05-2015, 05:07 PM
any updates?
