(#1826)
Outlawmotorsports Outlawmotorsports is offline
Car: 2020 Supra
Default 06-16-2020, 07:41 AM
Can someone provide input on installing the EWG Harness on my 2020 Supra JB4? I took a quick glance at it this morning and it appears there is already a wire in #9 where the purple wire is supposed to go. Am I missing something?
absaifan absaifan is offline
Car: Supra 2020
Default 06-16-2020, 07:48 AM
Look at it again, you must be reading it wrong.
Here's a pic I found online.
Car: 2020 Supra
Default 06-16-2020, 08:03 AM
Thank you! The pic i found online when i searched had the numbering order completely different.
Car: Supra 2020
Default 06-16-2020, 08:15 AM
Use the Burger Motorsports diagrams / videos to be sure, they explain it all well.
If you install the pin in the wrong hole, it'll be a mission to remove it without damaging the harness pin so be definate.
Kona61 Kona61 is offline
Car: A90
Default 06-25-2020, 03:34 PM
Hey guys, I had a question about the JB4 on an A90 Supra. For the usage of Map 4 and 5, you recommend the EWG wires and that's all? No BEF necessary? Also, if I can use it, how close do I need to get the E85 content for both maps 4 and 5?
Car: Supra 2020
Default 06-25-2020, 03:44 PM
I got the best power results using the EWG, it's worth to install it to better manage the boost up top.
BEF is an excellent add-on especially if you want to go for higher boosts and upgrade the turbo etc.
Can't comment on e85 as I never used it, sorry.
510W_MPP340 510W_MPP340 is offline
Car: Zhp 340 18
Default 06-25-2020, 05:11 PM
How much can a stock b58 turbo take up until blow lol... hp/boost. ?
Car: Supra 2020
Default 06-26-2020, 01:29 AM
18-20psi all day and 420-450 whp on pump gas, depending on your mods.
Gearbangin Gearbangin is offline
Car: Supra
Default 06-26-2020, 09:38 AM
Whats up all! I Have been running the JB4 on my 2020 Supra for several months on MAP3 with 93 Octane. I recently added the EWG added E40 using MAP 5. It was maxing out the fuel trims so I switched to E30 and MAP 4. (Terry gave me some good feedback)
Anybody have any feed back or suggestions to run MAP5 and an E blend?
xz329 xz329 is offline
Car: F30 330e
Default 06-30-2020, 08:58 AM
Am i the only one feeling older firmware making more power n higher boost than new firmware?
Especially v11 and v13 firmware feel more power than v16
Default 06-30-2020, 07:50 PM
The newer firmware is newer for good reason, but I always tell people, run whatever firmware they prefer.
Default 06-30-2020, 07:51 PM
If map5 is more than the fuel trims can handle, adding in our BEF at some point is an easy way to resolve that and allow 100% E85.
