DONZ DONZ is offline
Car: 2012 BMW 335
Default First time logging Please review!! - 06-02-2019, 05:03 PM
So this is the first log I have posted, the car isn't pulling like it should. No codes little bit of a rough idle. My mods are intake,CP,down pipe, secondaries cut out, 93 octane,map 2. the car is 2012 335xi jb4 with BEF. The car hasn't been performing ever since i did the BEF, if anything it seems a bit slower which is disappointing. Thanks in advance
Default 06-02-2019, 05:08 PM
Log actually looks pretty clean to me. Boost is where it should be, timing isn't too bad.
For comparison could get a log on map1 so we can see how it looks at a lower boost set point.
Car: 2012 BMW 335
Default 06-02-2019, 05:53 PM
Okay terry here's a log of map 1 strangely enough it felt better than map 2 but who knows
Default 06-03-2019, 12:41 AM
doesn’t shock me
Map 1 timing looks improved - I’d stick with 1 if it feels better / looks cleaner
Car: 2012 BMW 335
Default 06-04-2019, 07:34 AM
doesnít shock me
Map 1 timing looks improved - Iíd stick with 1 if it feels better / looks cleaner
So Iíve noticed my boost is under target and drops off pretty quickly on the big end should I adjust my duty bias or could that be a boost leak?
andrews013's Avatar
andrews013 andrews013 is offline
Car: 2013 E92 335i xDrive
Default 06-04-2019, 01:54 PM
I was wondering why neither of them mentioned that. Pretty far under target.
Car: 2012 BMW 335
Default 06-04-2019, 03:57 PM
Yeah so I realize that the target will drop the higher the rpm is but what I’m seeing is it will hold briefly at 19 lbs but by the time I shift it’s all the way down at 12 which would explain why it doesn’t seem to be pulling that hard can a tuner please chime in
