FLDrives FLDrives is offline
Car: M235i
Default Log review (will update later) - 06-01-2019, 07:19 PM
Okay so I went out and did a handful of more pulls to log. Here are the logs if someone could check and see if everything looks good Iíd really appreciate it. Iím a bit concerned itís running a bit lean with afr in the 13s and sometimes even 14s. I have CP, Down P, and the ewg wires. Iím running a 93oct/e85 mix of 4 gal so right around e30.
Default 06-02-2019, 05:09 PM
AFR is where it should be on the stock flash. If you want to take it to the next level you could consider our E85 BEF which gets timing up. But overall I don't see anything I'd suggest changing here.
Car: M235i
Default 06-02-2019, 07:59 PM
Awesome thank you for taking a look. I’ll have to check out the BEF info
Default 06-03-2019, 12:43 AM
Originally Posted by FLDrives
Awesome thank you for taking a look. Iíll have to check out the BEF info
Dooo it
Wonít regret it!
