435gc 435gc is offline
Default Log review please - 06-01-2019, 04:11 PM
Hey all
I have attached 2 logs. 1 is in map 1, the other is map 2.
I am curious as to your thoughts on both.
I have a 2015 435i auto transmission with xdrive.
I have NGK 97506 gapped to 0.22, BMS intake, chargepipe, and FMIC.
Car felt good on both pulls. Maybe a bit stronger on map 2. For fuel The tank has 93 octane with 3 gals of ethanol pump gas. The pump station said the ethanol content can vary from e50 to e83.
I am a bit confused why I am not getting all cylinders ignition logged and why my boost targets are much lower that my actual boost. I also thought I would be hitting higher boost then I am.
Thank you !!
Default 06-02-2019, 05:13 PM
Update to the latest v15 EWG N55 firmware for starters and relog map2!
Do you have the EWG connector installed? That might become useful here also on map5.
Default 06-03-2019, 03:10 PM
Firmware updated.
Odd that it wasnt the most current version. I just bought the jb4 a couple weeks ago and the vendor said it would come with the latest firmware.
I do not have the ewg attachment. The vendor who advised me on my purchase(xtreme powerhouse) noted that it was not needed for my setup, as it was for "higher horsepower applications." Is this inaccurate? Do i need to order it?
Two back to back logs in map 2 attached as requested.
Thanks for the support Terry.
Default 06-06-2019, 12:27 PM
Bump
Default 06-12-2019, 03:57 AM
Bump
Default 06-13-2019, 10:59 AM
Originally Posted by 435gc
Firmware updated.
Connector would be helpful, but not "needed"
Log looks a bit cleaner- how does the car feel
Default 06-13-2019, 11:42 AM
The car feels good. No issues with drivability. Does the boost level look appropriate?
I also have a map 5 pull here. Boost is not hitting target, any thoughts here?
Thank you so much.
Default 06-21-2019, 05:54 AM
Bump
Default 06-25-2019, 05:53 AM
How does my log look?
What benefit would I see if I were to install the the ewg connector with my mods?
Thank you!
Default 07-07-2019, 10:11 AM
Bump
