(#201)
Eric97h Eric97h is offline
Car: Bmw 340i
Default 06-10-2019, 02:10 PM
EWG connector right? Set FF to 60 and relog map3 and map4, so we can get boost up closer to the intended target.
Here is map 3 and map 4 after doing that adaptation ? Do you think map 4 is safe to run without meth ?
2 map 3 2 map 4
Default 06-10-2019, 04:20 PM
Here is the issue... On map4 fuel pressure is starting to crater. So I'd stay on map3 for now.
Car: Bmw 340i
Default 06-10-2019, 05:14 PM
Ok thank you I will use map 3 it ran completely fine was really fast too if I get meth I will run map 4!
BMW After BMW
Car: BMW M240i
Default 06-10-2019, 07:25 PM
Meth helps a whole lot with the hardware fuel limits on this platform, if you want to make more power. That said: there are lots of variables so what works for one may not work for someone else. Have fun experimenting.
ziyadeth ziyadeth is offline
Car: M240
Default 06-11-2019, 08:22 PM
Here is a log. I don't have access to e85, so 93 octane it is.
17 M240I - 6 Speed - FBO - PS2 - WMI (M1) - MHD BEF +JB4(FF and EWG wires)
JBoe JBoe is offline
Car: M240i
Default 06-11-2019, 08:49 PM
They do or wait for our USB-C cables. Should be here in a few weeks.
Hi Terry... are the USB-C cables available yet? I want to get the BEF and maximize my stock turbo WMI setup asap.
Default 06-11-2019, 09:30 PM
Sorry not yet. Just get an adapter or buy a $40 android device that has MicroUSB.
rf30a rf30a is offline
Car: F30 328ix/C300 W205
Default 06-12-2019, 01:06 PM
Anyone else experiencing a rough idle on startup with the cold start disabled?
Default 06-12-2019, 01:25 PM
Disabling cold start as a flash time can sometime cause cold idle issues. I'd leave it on.
Default 06-12-2019, 02:04 PM
Thanks Terry!
Car: Bmw 340i
Default 06-12-2019, 10:10 PM
hey is it possibel to use the race gas map back end map just do full 100 octane will it run better or even faster than e40?
Default 06-12-2019, 10:32 PM
Yes with unleaded race fuel you have more tuning flexibility as fuel pressure is less of an issue.
Default Map 4 e85 logs - 06-14-2019, 05:23 PM
Hey,
Attached are some map 4 and a map 5 e85 logs. Running e40 with 93 octane base. Let me know how it looks.
Thanks,
Ron
Car: Bmw 340i
Default 06-14-2019, 07:05 PM
Originally Posted by rf30a
Hey,
Attached are some map 4 e85 logs. Running e40 with 93 octane base. Let me know how it looks.
Thanks,
Ron
Dam map 4 didnít work out so well with me e40 91 octane hope it works good for you
Default 06-14-2019, 07:21 PM
Fuel pressure looks good, and trims seem okay so, I think it is good but want to check with the experts. 93 octane as a base must make a difference too.
