(#576)
echacon echacon is offline
Car: Cooper S F56
Default 05-14-2019, 09:29 AM
There is a safety system to prevent you from requesting more than 10psi over the flash target.
Is it possible to turn off this safety system?
Chrisf56Mini Chrisf56Mini is offline
Car: F56 Mini Cooper s
Default 05-15-2019, 03:24 PM
Iím getting invalid read when reading codes on the latest firmware also is there anything new about the latest firmware than the previous one?
Default 05-29-2019, 02:41 PM
Yes but we keep that under wraps because it's not suggested.
Car: B46 F56S
Default 06-08-2019, 06:38 PM
Terry,
How can we test that boost safety on the new firmware is operational?
I tried setting it to 16, 15, 14 psi and never got it to switch to Map 8.
Default 06-10-2019, 12:00 PM
Log of it set to 14psi and boost exceeding 14psi so I can look at the details?
Car: B46 F56S
Default 06-12-2019, 06:56 AM
Yes. Here you go.
Driving on the mountains on the way to Reno so may be variation between the logs.
Also, if you end up rebuilding the firmware, we can try other things to get the code read to work if you have time.
Thanks.
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 06-13-2019, 03:52 AM
Originally Posted by johntotah94
Yes. Here you go.
Thanks.
Is there a new firmware to test; @john I see your running map6 thought you were running meth which should be map3 as the emu map?
Car: B46 F56S
Default 06-13-2019, 04:11 AM
Testing a new firmware posted a few pages back. I requested it because I now have a flash tune but would still like to have safety features active of the JB4.
Essentially I run Map 6, 0 psi on values, Meth Trigger = 1.
If a safety hits, it should revert to Map 8 which is like a low power valet map.
At the current status, Iím having trouble with the safety switching to Map 8 and I cannot code read.
Jay1312
Default 06-14-2019, 01:19 AM
Both version of hex6 doesnít work for me.As before invalid code read.
@John if you got meth can you not run map3 which is the wmi map from hex4?
Is your flash a standard flash or a bef?
Car: Cooper S F56
Default 06-14-2019, 04:29 AM
I had to remap the ECU to get 21 psi flat, it is a pity. EA888 JB4 is much better...I could use any pressure i wanted.
Car: B46 F56S
Default 06-14-2019, 02:22 PM
Itís a standard flash. Not a BEF. As they are not available yet.
I suppose I can run Map 3 with additive at 0 also.
But the ultimate goal is when safety hits, needs to go to a safe map.
Switching to Map 4 on the standard JB4 firmware wonít do anything as the ECU is flashed. So switching to Map 8 is the current work in progress solution since itís like a forced Valet mode on the JB4.
