(#76)
Default 01-11-2017, 09:36 PM
Was working on the Z06 today and had a chance to do some back to back runs with and without the updated taller supercharger lid.
Testing was done on E30 with a conservative lower torque tune that consistently gets no knock retard. Makes for nice and consistent numbers run after run. Normally within 1-2whp. Car has tuning, a 2.3" pulley, and intake as its only mods.
Anyway I did a round of runs, installed the lid (took 10 min... its a lot of little bolts!), and did another round of runs. I kept the cooling time consistent between them and the chart represents basically the average of each set.
Overall the runs with the taller lid were consistently ~10-15whp higher via higher engine boost.
So if you're looking for a good way to spend ~$650 on your 2015-2016 adding in the 2017 lid and hood liner is an option. My CNC guy looked it over and got the wild idea to explore making an aftermarket CNC lid that is even higher volume, so we'll see if anything comes from that down the road.
Default 01-11-2017, 09:46 PM
Basically the theory goes the taller lid improves flow through the intercooler bricks under it, less abrupt turn, allowing a little more boost all else being equal. IATs were similar but boost was higher, so the theory makes sense.
Default 01-11-2017, 10:00 PM
Space is a factor, this taller lid required a new interior hood liner to clear. At least Chevy improved power for 2017 models with this lid. The 2017 models also have the intercoolers angled slightly differently to take advantage of the extra space.
blipit blipit is offline
Car: 335
Default 01-18-2017, 04:10 PM
Z06's are no joke with minor mods.
Some guys are dipping into upper 9's @ 140 with about $2,500(intake, pulley, xpipe, 93 tune, DR's).
Default 04-10-2017, 08:58 PM
I've been slowly working on the Z06 intake system. What I've been able to confirm via flow testing is that the factory intake piping and MAF housing are themselves not restrictive at all. They could probably support 900whp. But the thick drop in filter base itself is where the problem is. It's molded such that it blocks off potential airflow in to the MAF housing.
To address this we designed a drop in filter that has a thinner and less restrictive base to better mate up to the factory MAF housing, kept the filter DRY to avoid oil contamination on the MAF, and using a flow bench optimized the pleats and other dimensions.
The net result was a drop in filter that offers 15% less restriction than factory and 10% less restriction than the "leading" aftermarket drop in filter, when flowed tested through the factory intake piping. We actually went further and found a simple way to modify the airbox to accept a longer drop in filter that offered even less restriction, but after dyno testing, determined it was overkill.
With first articles of the new drop in and our trusty AFE intake in tow I headed to the dyno today for a few hours of testing.
The test car is a 2016 Z06 automatic that I've tuned with HP Tuners. I run it on 6 gallons of E85, rest of the tank 91 octane, and I've tuned it for a low 12s AFR and around 21 degrees peak total timing, with timing as low as 10 degrees in the midrange to reduce torque for traction purposes. Overall a conservative tune. The car has a 2.3" upper pulley, home ported throttle body, and 2017 supercharger lid.
Since output can vary day to day based on weather, fuel mixture, and other minor factors I did a few pulls with the AFE intake on to ensure I had a good baseline for the day.
Next, I switched over to the factory airbox and first tested the stock air filter. To keep everything apples to apples I had to go through the tuning and "undo" the various changes I had made to compensate for the AFE intake misreading the MAF. Primarily MAF sensor scaling, PE changes, and a minor adjustment to the base timing curve to keep timing and AFR similar. So often tuners fail to isolate variables which are what generally lead to wild and misleading test results.
Once everything was matched up I did a few runs and took the best of which to compare with the best AFE run. As expected with the AFE boost was marginally higher resulting in 10-15whp gained. Not the 30-50whp result people get when comparing a too-rich stock tune to a much leaner and over-timed intake only result (due to unintended MAF rescaling).
Next I switched over to the BMS drop in filter we're evaluating. I was expecting no additional tuning changes to be required vs the stock filter to arrive at the same low 12 AFR I run the car at. But to my surprise, the AFR was much leaner than I wanted with the stock MAF tuning. About 5 pulls later I realized I had to put in almost every change I had made for the AFE intake. And when doing so, matching up the AFR and timing curves, power with the BMS drop in was basically identical (if not slightly better) than the AFE intake.
I had set out to design a drop in filter that would give OEM AFR and timing values while allowing more flow. And what I ultimately discovered is that it's impossible to do so. If you improve the airflow MAF calibration differences are unavoidable. On the plus side, with this new drop filter, there is no longer a need for expensive and IMHO ugly intake systems. But we're going to have the same annoying problems that everyone has with the intakes now. Some cars will likely work fine with their factory, some might need tuning to enrich the AFR, etc. Little variables like whether your fuel is E0 or E10, elevation, DME version, will all play a role in that.
Anyway I've decided to move forward with the project and have a bunch of filters in production. When they arrive I'll start soliciting testers and get some 2016 and 2017 stock vehicles on the dyno to better quantify things for untuned vehicles. For those tuned who don't like the look of their aftermarket intake... You'll have an OEM looking alternative soon.
PS. I have a slightly used AFE intake system for sale.
T-cash702's Avatar
T-cash702 T-cash702 is offline
Car: BMW 335is
Default 04-15-2017, 06:23 PM
Terry, are you going to be releasing any piggyback or tune for this Z06 model? Or any aftermarket options? Or is this all your doing for fun?
2011 BMW 335is DCT E92 AW Fully loaded M sport everything/coral red interior with snakeskin like panels/Premium 19" style 313M [NOW]
JB4 G5 ISO/BMS DCI/ER CP+HKS BOV/VRSF MEOWLESS ***/STOCK RFTs
12.57 @ 114.81 @ PACIFIC RACEWAYS KENT,WA
Default 04-15-2017, 07:46 PM
No piggyback plans for it since its so easy and cheap to tune via HP Tuners. It's tempting to make a MAF translator like product since the tuning is so heavily MAF based. But, I think we'll just do the high-flow drop in filter, maybe a couple little CNC parts, and call it a day. Awesome car though.
Default 05-04-2017, 08:00 PM
I had some spare time today, and straight 91 octane in the Z06 tank, so I decided to checkout the 91 octane only tuning. Compared to 30% E85 minimum best timing is significantly lower as is total power output. Overall happy with the 91 octane map though. Will make for a good backup when I don't have the time to mix in E85.
Mods on the car are BMS drop in filter, 2.3" upper pulley, home ported throttle body, HP Tuners.
In terms of running the drop in on the stock tuning it's still an open area. We'll see how user feedback goes. At the very least for those tuned this is a great alternative to expensive intake kits.
Also started setting up a page for it.
T-cash702's Avatar
Car: BMW 335is
Default 05-04-2017, 11:23 PM
Just drop a tune already Terry!
Default 05-05-2017, 08:33 AM
I posted a free HP Tuners E30 and 91 octane tune for it on the Z06 forum.
Default 05-16-2017, 10:18 AM
Had a customer send in some dyno files on a stock 2015 A8, 91 crap-tane, stock filter vs. BMS drop in.
Default 05-16-2017, 12:51 PM
Only 15hp of that is from the higher flow of the filter. The rest is from the leaner air/fuel ratio since the filter does some minor MAF rescaling. Basically, it's the same effect you get with all the Z06 intakes. Only it's $90 and looks stock.
Default 07-03-2019, 04:44 PM
Due to a lot of requests we ordered in a new GM high performance airbox and are working on optimizing a new drop in filter for it, like our current Z06 drop in filter. At quick glance we'll be able to make the opening larger, filter longer, with more pleats, and less cage structure for higher flow! w00t!
Default 09-24-2019, 04:52 PM
Model of our filter for the GM airbox in testing now! Dyno results here: BMS Drop in for Corvette C7 GM Performance Cold Air Intake Dyno Testing - N54Tech.com - International Turbo Racing Discussion
Newguy123's Avatar
Car: 12' 135i
Default 04-02-2020, 08:03 AM
Good read and great data, so from the sounds of it I should take the roto fab intake off the zl1 go back to stock intake with your drop in maybe run some e20 and see if I get any codes. Maybe I’ll hit up Jesse and do a comparison on his dyno using 91 with this roto intake vs your drop in (if airbox is same as your c8) and then try dumping a few gallons of e85 in and repeat on the stock map.
18 Glacier white RS3
#PURETURBOS
#FUELIT
