Originally Posted by azimov308
I'm having a weird problem almost a year after replacing my turbos. The rear turbo will blow smoke when stopped and when I'm driving it hard it misfires in mainly cylinder 6 but sometimes 4 and 5. There's oil on the outlet pipe and lower half of the wastegate actuator (shown in the picture). Could this be because of bad drainage or unequal turbo pressure? I can't imagine I have any shaft play this early.
https://imgur.com/a/P4VDd46
I've since installed a catch can, walnut blasted my intake valves, replaced the stock inlets with silicone ones. I also have an upgraded metal pcv valve and will be trying to replace the oil return line.
Any guidance would be greatly appreciated!
At first glance, oil in that location is much more likely to be coming from the valve cover and falling down
however the lack of oil in the catch lip along the edge looks clean and clear, so, not sure.
If you run the engine with no cover/plastic over it, and also no cowling, the rear cylinders tend to be much more environmentally exposed than you may first realize. Water will drip down the windshield and its collect/drip point in the cowl (with shields removed) is right above the cylinder 6 coil pack
When diagnosing misfires on these cars, its very important to have very very clean components. You have no idea how many times I have seen my friends throw away "bad coil packs" that have dirt or oil in the tips. Or chased nightmare "injector" issues that turned out to be just an exceptionally oily plug hole. I would put much more of my gambling money on something along those lines being the problem, highly doubtful a bad rear turbo would boost fine but cause misfires unless it was shoveling half its feed oil past the front turbo journal bearing and sucking all that oil into the motor. Also check your plug gaps, and I would recommend running the NGK 97506 gapped to .020 or .018. Tried lots, never had a plug better than those on this platform. Don't expect more than 15k miles of life when running 12deg of timing tho, lol.
How do you know its only one turbo smoking? Do you have individual pipes with no cross at any point? How does the car boost, do you have any gate rattle?
EDIT: Oh yeah also check your ground posts on the valve cover. I had a multiple cyl misfire under load I chased for a few hours and almost threw parts at before I realized that the catch can line pulls on the pcv attachment point on the cover. This makes the oring slip out, and pcv oil drip from very high up on the cover. Could be your issue here, it may be following the catch can line from that loose attachment fitting before dripping down. Also may be dripping down between the cams there too. Worth a look.
