Car: 2006 m5
10-10-2017, 05:20 PM
I see this is a pretty old thread.
If the OP is still alive. ..if I brought my 2006 m5 smg to you with the dct installed...how much wod you charge me to get the electronics hppy and working? I am really not interested in figuring out all of this wiring g etc. Call me lazy if you like. I don't mind installing the tranny and getting any necessary adapters made and installed.
I set up an account here so that I could ask this question.
Car: 2005 BMW
12-04-2017, 11:04 PM
Any updates if someone tried to do the same on other models?
Car: 2009 335i E91 Touring
12-05-2017, 06:03 AM
What other models?
Car: 2010 bmw 535
01-15-2018, 06:31 PM
Would this work on an e60 n54?
Car: 2010 E91 335i N54
12-13-2018, 04:33 AM
I'm about to replace the 6AT in my 2010 E91 with a DCT. Since my car is fairly recent most parts of this tutorial are not required for my car.
Sadly I do still need the diagram for the harness that needs to be made. This does not seem available via the FTP link provided.
So, is there anyone who can help me out with this?
Cheers!
Richard
2010 E91 335i - Le Mans blue
Intercooler upgrade, exhaust upgrade, chargepipe upgrade, Stage 1 LPFP, N20 TMAP.
JB4 Map 7 - MHD Back-end Flash RACE.
About as fast as you can go without having to eat airlinerfood.
Car: 2010 335i
12-20-2018, 01:56 PM
Cheers!
Richard
Have you looked over on spool street? Most of the info is relevant. I'll see if I can find my notes from when I did mine. Which is a 2010 e90 so wiring should be really close. Do you have all the parts needed already? Feel free to pm me. It may be a few days before I can get the info for you.
JB4, PT5858 ST, 3.5" exhaust, VMR V710, KW V3 coilovers, Wavetrac LSD, AKG subframe and diff bushings- Hybrid Ovations, Jehnert Doorboards, IDMax15 and 2 Arc Audio 1200.6 amps, white gauge cluster
Car: 07 e90 335i
02-01-2019, 11:55 PM
Got a a/t dme/ cas/ ignition key switch/ key fob for my m/t 335i, is everything plug n play or do I have to code them to my vehicle
Car: BMW 335
02-23-2019, 10:08 AM
Hello to all. can I use DCT transmission from M4? I have DCT transmission from M4 and M4 flywheel? anyone has experience?
BR Alex
Car: BMW 335i
10-15-2019, 02:45 PM
Originally Posted by ncat10
Dedicated steps to swap AT on DCT
Replace DSC Sensor Plug. The DSC sensor should be connect to DSC unit follows
DSC UNIT > DSC Sensor
39 > 4
27 > 2
11 > 3
28 > 1
A little of correction. The F-Can goes to 11 and 26, not 11 and 28. And the pin numbers of the sensor are 3,5,2,1 of the sensor (instead of 4,2,3,1). Final mapping would look this way:
39 -> 3
27 -> 5
11 -> 2
26 -> 1
Also, it wasn't easy to realize that "OLD X6031" is in fact the BODY side that needs to get pins swapped to X6021 (body side again).
Other than that - its flawless. Many thanks for the writeup.
2007 335i MT N54
MHD+JB4 Garret GTW3684 ST
FMIC, DP, 3" PIPES, Fuel-It Stage 1, MF LSD.
10-15-2019, 11:32 PM
39 -> 3
27 -> 5
11 -> 2
26 -> 1
Attachment 90539
Which year was your car?
Car: BMW 335i
10-16-2019, 01:00 AM
Mine (body) is 2007/4 but in fact it doesn't matter, the DSC sensor's wiring sits as follows on every RWD model with dsc_85 & dsc_87:
39 (CLUS SP, wires to sensor pin #3)
27 (CLUS GND, wires to sensor pin #5)
11 (F Can High, wires to sensor pin #2)
26 (F Can High, wires to sensor pin #1)
Here: A65a Dynamic stability control (DSC)
Guess 28 was just a typo in the original post, as it's not wired in any modification except AWD models (wheel ABS/DSC), and 26 is the pin for FCAN H signal needed for the sensor
PS: AWD models have different DSC and totally different pinout to the sensor.
2007 335i MT N54
Car: 08 135i
03-14-2020, 01:41 AM
One of the more interesting threads...
@e82n54 -- 11.3@122 -- stock turbos, stock exhaust, stock suspension
Car: Bmw 335i 2007 N54
05-13-2021, 02:40 AM
Hey, Why are you talking about pin 5 when the new dsc pump connector is a 4 pin connector?
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
BMS WMI with single nozzle ( 10 )
JB4 map 3 w/bluetooth & antiliag
Afe intake filter
BMS intercooler
BMS tranny cooler
BMS Double baffle catch can
MHD BEF Racegas
Precision Raceworks Coil
-Running 91 octane with WMI
Banned
Car: 2011 BMW 335i
one mo -
05-27-2021, 12:40 PM
