Specktor Specktor is offline
Banned
Car: 2011 BMW 335i
Default 2011 335i code help - 08-13-2016, 12:00 AM
So after putting the car into map 1 with the JB4 I go WOT to over take a car in 5th gear and the car goes into limp mode and starts to misfire.
The codes are as listed:
2F04
2F02
0000
0000
2EE0
2EF4
2EED
2F01
00F1
the mods i have on are a BMS n55 intake, CXRacing charge pipe, and the JB4 tune.
If anyone can help it would be much appreciated.
keyap keyap is offline
Car: N55 135i
Default 08-13-2016, 12:37 AM
Would be good to know the meaning of the codes. You can get details here:-
http://www.n54tech.com/forums/showthread.php?t=1895
Banned
Car: 2011 BMW 335i
Default 08-13-2016, 12:48 AM
alright my bad for not putting the description earlier
2F04: Cyl 6 Misfire
2F02: Cyl 4 Misfire
0000: No Description found
2EE0: Combustion misfiring, several cylinders: Fuel injection deactivation
2EF4: Combustion misfiring, cylinder 6: Fuel injection deactivation
2EED: Combustion misfiring, cylinder 4: Fuel injection deactivation
2F01: Cyl 3 Misfire
00F1: I couldnt find that in the .pdf for diagnostics fault codes
Default 08-13-2016, 12:25 PM
You'll need to post a log but looks like you have quite a few misfires. It may be fueling related, plugs, coils, injectors....
First place to start is by logging, then systematic troubleshooting.
